I wanted to delete one file, but I use this file to transfer from Figma to Framer using the plugin 'FIGMA to HTML with Framer.' Will my Framer website be messed up if I delete the Figma file design?
  • October 6, 2023
  • 304 views
So, I am on the Free Starter Plan, which has a limit of only 3 files. I wanted to delete one file, but I use this file to transfer from Figma to Framer using the plugin ‘FIGMA to HTML with Framer.’ Will my Framer website be messed up if I delete the Figma file design?
Celine_
  • 3751 replies
  • October 17, 2023
Hi @Daniela_Golden ,
I saw in our backend that our team replied you. Here the answer for visibility to the community if anyone encounter this issue:
To use Framer, it looks like you copy and paste your Figma content into Framer in order to convert your design to code. That said, it sounds like Framer itself is using copied content, in which case, deleting your Figma file would not have any impact.
However, I would recommend reaching out to Framer directly to confirm. As all of our plugins are created by Community members and not Figma, Framer will have more insight.
You can find the support email for each plugin on that plugin’s homepage:
Hope it helps!
