How to hide element in prototype?
  • March 18, 2021
  • 8 replies
  • 26104 views
h.rude
Hello 🙂
currently I’m working on a prototype and I have a list with removable listitems.
I’m using Autolayout and by letting the user click “x” on the listitem, I want it to be removed from the list. Is this possible in Figma?
Best answer by Gleb
No, this is not possible to do in a “programmatic” way, but you can create another frame with one item removed and transition to it when the remove button is pressed.
  • 4708 replies
  • March 18, 2021
h.rude
  • 42 replies
  • March 18, 2021
Hi Gleb,
thanks. I hoped that I could do a bit more realistic prototype without having tons of frames, now that interactive components had been released. Very unfortunate. But thank you! I will go with that workaround.
  • 4708 replies
  • March 18, 2021
Interactive components are still in beta and they don’t support auto layout at this point, but when they will be released they should work with auto layout so this might be somewhat possible.
mbrus
  • 5 replies
  • May 6, 2022
Hey, I have the same need as @h.rude. Without an ability on “Click → Show/Hide X” I have to create many more frames and interactions which feels unnecessary. Is something like this planned?
Jorge_Tello_Aliaga
I believe this is now posible with Variants (where buttons can have multiple states). https://help.figma.com/hc/en-us/articles/360061175334-Create-interactive-components-with-variants
h.rude
  • 42 replies
  • May 11, 2022
Is it? You’d still need to either create a new flow frame, where the items is deleted. Not sure how the variants can help. I’m not able to create the frame smaller than 1 px - so there will always be a remaining bit of the variant. I cannot fully remove it. Or am I missing out something?
Figma – 11 May 22
Diego_Vogel
@h.rude @mbrus
I figured out a workaround for this (with one caveat).
  1. Create a variant which is just an empty frame. Set the height and/or width to 0.001 (you can’t set it to zero). I used a property called “Dismissed” for this, set to false for all variants except the empty variant.
  2. Add interactions to change to the empty variant when the dismiss/close button is clicked.
In the prototype, when you click the close button it will switch to the empty variant with a height of (almost) zero. The caveat comes when the component is placed within an auto layout that has space between items. If you dismiss/close the element, it’s technically still there, so the space around it will not go away. It’s not a perfect solution, but at least communicates the intent in a prototype.
If anyone has a way to make a truly empty variant this would solve the auto layout spacing issue.
Diego_Vogel
@h.rude I didn’t see your last post. I guess you already figured all that out 😆
