Hi all, I have created the following interaction so far. Once the user clicks “4”, the component changes to the variant with the square around it to show that “4” has been selected.
Here is what I would like to do now: Only when “4” is clicked (and the square around it shows), the text layer with the text "Monday 4th March, 2024) shows below the calendar.
On the click interaction of “4” add a Set variables on top. Set fullDate to your desired text (i.e: Monday, 4th March, 2024), and then go to the next view
Hi @Haroll! This is super helpful. Thank you so much! It worked for me
One more question, this works well for me. However, I haven’t 100% got the interaction I wanted. On the click interaction with 4, it changes to 4 with the square border around it. I then have to click it again to show “Monday 4th March 2024”.
Is there anyway that I can do the click interaction with 4 for the first time and for it to change to 4 with a square and show the date at the same time?
I’m sorry I illustrate an interaction between two frame while you were looking for a interaction between variant. What you need to use is a Change to action
Basically use the same interaction and prepend it with the set variable for the date,
