How can I fix a nested element size when resizing its parent component?
  • February 25, 2021
  • 4 replies
  • 3811 views
jwjwjw111
I can’t find any options to fix its size.
in this video, arrow size has to be fixed when the parent group is resizing.
Josh
  • Former Community Manager
  • 1019 replies
  • February 26, 2021
make sure to constraints are set properly on the main component. From the video it looks like you’re showing the instance.
jwjwjw111
  • 4 replies
  • February 27, 2021
hi. Josh. I tried it onto other non-instance layers too. but it still didn’t work. =(
chudoloo
  • 35 replies
  • February 27, 2021
The layer “Group 681” is a group and not a frame so its contents will always scale. You’ll want to convert “Group 681” into a frame. “icon_arrow” will then sit center/center with a fixed size but you probably want “Ellipse 7” set to Scale or Left and right and Top and bottom.
jwjwjw111
  • 4 replies
  • February 27, 2021
ah~~~~ thank you chudoloo!! it solved!! 👍 😀
