Hover state reverting to the first variant?
  • January 19, 2024
  • 182 views
omri1
hello everyone
im trying to build a color picker component using hover states to match the background color with the selected swatch.
but when i hover between swatches you can see a flash of the default variant.
i tried going through all the groups ad making sure the naming and order is correct
any ideas? see the attached link
Figma – 19 Jan 24
Raphael_M
  • 394 replies
  • January 22, 2024
Hi, Omri.
Hover only change the variants when being hovered and then reverts back to the initial variant upon leaving the hover. So, Instead of using hover, you might need to use the mouse enter event. There is a copy of how it will be using Mouse Enter inside your file.
Bonus (If you are in a professional license or higher, you may opt to use variables and set variable conditions to create the prototype with less frames):
