Getting this error while inserting instance from design system.
  • October 17, 2024
  • 29 views
Irfan_Ali
Please search for existing topics before posting! Press 🔍 at the upper right to search.
Screenshot 2024-10-17 at 3.05.52 PM
Getting this error while inserting instance from design system. Any one facing same issue ?
Celine_
  • 3477 replies
  • October 17, 2024
Hi there, thanks for reaching out to the community.
As a first workaround, please clear out the cache to see if that helps.
You can clear the desktop app cache on a Mac in the Help menu under Troubleshooting. If you’d prefer to manually clear your cache you can:
  1. Quit the Figma desktop app
  2. Open Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma"
  3. Try opening the desktop app again
You can clear the desktop app cache on Windows under the toggle-arrow at the right of the top toolbar under Help > Troubleshooting. If you’d prefer to manually clear your cache you can:
  1. Close the Figma desktop app
  2. Open the Start menu, and paste in this, followed by enter: %APPDATA%\Figma
  3. In the window that opens, delete the Desktop and DesktopProfile folders if they exist
  4. Launch the desktop app again
If you are still running into issues, please reach out directly to the support so they can investigate further the root cause of your issue: here
Please use your Figma account email, include a link to the file, and add support-share@figma.com as an Editor, and share your console log (you can follow the steps in this article here) so they can take a closer look. Thank you!
Irfan_Ali
  • October 17, 2024
Thanks for the response. I am using Figma in Web. So give me solution for web plz.
Celine_
  • 3477 replies
  • October 17, 2024
For the browser, you can also try to clear out the cache to see if that helps:
And if this still doesn’t help, please reach out to the support team and follow the instructions as mentioned below: here Thank you!
