Full width button variant
  • January 16, 2024
  • 8 replies
  • 1568 views
Dennis_Kuiper
Hey all,
I was wondering I want to create a button that has a full width option so it will fill in the frame it has been placed in. Is there a way to achieve this? Can’t seem to figure it out.
Raphael_M
  • 394 replies
  • January 17, 2024
Hi, Dennis. If you put the button inside a frame with auto-layout, you can set it’s width/height to fill where it will fill all the space.
For more information regarding auto-layout, check this tutorial by Figma (albeit, its outdated 😅) https://www.youtube.com/watch?v=TyaGpGDFczw&ab_channel=Figma
Dennis_Kuiper
Hey @Raphael_M thanks for the reply!
Is it possible tho to make a button (component) and give it a variable full width so it will automaticaly make it fill container?
Raphael_M
  • 394 replies
  • January 17, 2024
Yes. Add an auto-layout in your component with variants and set all the variants to fill container.
If you paste the instance in a frame with auto layout, it should automatically fill the space.
Dennis_Kuiper
Hey,
The thing is that it doesn’t seem to work consistently for me. I need to manually do a fill for the one with the full width before it uses it correct.
Raphael_M
  • 394 replies
  • January 17, 2024
Hi. Have you checked if the frame where you will put the button is on auto layout? Because in my end, it works properly.
Dennis_Kuiper
Yeah the thing is if I drop the component from the left drawer into that frame and change the variation to full width it turns to fixed.
Raphael_M
  • 394 replies
  • January 17, 2024
Hi. Will you be able to show me a video example if you don’t mind? Thanks.
Viktor_Wrange
Has anyone found a solution for this? I’m having the same issue.
My Default button variant is set to hug and I want a second Mobile button variant that should be set to fill width. Dragging in the Mobile button variant into an auto-layout with fixed width it works and the button fills the entire width of the auto-layout. But if I first drag in the Default button variant and switch to my Mobile button variant it changes to fixed width and has the same width as my main component.
