Font does not change when changing the variable
Sanny
  • 25 replies
Hi,
I’ve noticed an issue with changing the font family in the variables modal. The font does not update across all pages and components automatically. The font can be changed to the correct family when double clicking on a text box.
Cheers,
Sanny
Sanny
  • 25 replies
  • May 28, 2024
As you can see the font styling is changed in this example (“Ag” is in a serif font)
But the text in the button is still the old.
After double clicking the textfield, the font is adjusted to the correct form.
Sanny
  • 25 replies
  • May 29, 2024
Is this a known bug? Has anyone else experienced this issue? Are there any workarounds?
Sanny
  • 25 replies
  • June 3, 2024
I found a solution to this problem, but it is not the desired way of working. It feels like font variables are not real variables at this moment.
You can use the command “Recompute text layout in selection” to update the text boxes. However, this requires manually running the command on every single page in your document after changing the font family variable.
For more details, refer to the discussion here: Update all text boxes with new version of font.
SJH
  • 6 replies
  • June 13, 2024
Also experiencing this issue.
Neither command worked for me.
SJH
  • 6 replies
  • June 17, 2024
Update from support is that it “sounds like the tool isn’t behaving the way we’d expect it to.” My ticket has been sent to the Technical Quality team.
Gaetan_Ark
Just found a workaround
  1. After a variable swap, the font family is not change ?
  2. Select the components or frames containing your components;
  3. Resize (K) and cancel the resize immediatly;
  4. The font is magically updated.
HeyItsBob
  • September 24, 2024
I had to take it a step further and actually resize all the frames and undo it immediately. The fonts all loaded and stayed that way after.
David145
  • October 2, 2024
Is there any official update on this? I have the same issue; variables for text don’t apply or they do so in really bizarro ways (like having to click on every text container to get it to change).
  • 4 replies
  • December 5, 2024
Same issue here. The command lines and the resizing did not work for me. I have to manually re-apply the same text style (that was already applied) before the style is updated.
Nouela
  • 18 replies
  • January 14, 2025
Same issue. Seems to be related to the colors also not updating in random cases. Clicking inside, changing anything, then undoing, seems to fix both issues, but dear lord is it a time suck. Please fix.
Celine_
  • 3732 replies
  • January 15, 2025
Hey everyone, thanks for flagging this and apologies for the delayed reply!
I was able to find the support ticket from SJH, and can confirm that this is a bug that our team has been investigating since June. (Typography variable applied incorrect Font Family). Unfortunately, we don’t have a timeline to provide on when to expect a fix, but we’ll pass this topic onto the team as they continue to work on it 🙏🏼
For others who encounters another issue (outside of typography variable), please reach out directly to the support team by filling out this form: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Our support team can investigate further your specific issue. When reaching out to the team, please share a quick video recording when you encounter the issue, the URL of your affected link and please invite support-share@figma.com with "can edit" permission, so they can take a look into this and try to replicate the issue on their end. Thank you
VarunYellina
Same here. Only way to fix is manually reapply the style to every single text layer. This renders the Modes in Variables useless. There is no way for me to test new font styles in design by taking advantage of Modes.
Daniela_Cortes2
Hi having, the same issue here, I updated the Font Family and it’s not updating across all components.
Danny Baker
Still seems to be an issue. :/ Anyone figured out how to get around this effectively?
