Figma Export adding additional text
Kieran_Kelly
Hello there,
I have a component image with a set of variants, but have an issue when Figma Export
it seems to be adding additional text as a prefix, how do I remove / stop this?
the bit it bold is being added, no idea why
Haroll
  • January 22, 2024
Hi @Kieran_Kelly
Export instance of your component’s variant instead of the component’s variant itself
the par you put in bold is the name of the variant inside your component, which is created according the component definition
i.e : a component button with one variant : type = primary and secondary
the variant’s layer name would be type=primary and type=secondary
Kieran_Kelly
Thanks @Haroll , thanks for the Reply!
Essentially the problem is, I do not want Figma Export to ever show
Property=ExampleTitle
This is due to a conflict with our internal filenaming convention (Games Studio).
I have a work around, I am just going to use a third-party plug in called Frame Exporter
