Disable image border by default when importing images into FigJam
  • February 19, 2024
  • 14 replies
  • 3090 views
Tricia
When I export images/photos that were placed in FigJam file, all photos export with this thick white border. Is there workaround so that the images export as if in normal Figma design file, ie, without the border?
Celine_
  • February 20, 2024
Hey @Tricia,
To give you some visibility, this extra padding is the expected behaviour for FigJam, but if you copy and paste the content over to a Figma Design file, you should have much more control over how it exports.
If you’re not using Figma Design regularly, then Export from Figma and Export formats and settings may be helpful in understanding the options available for different exports.
As a workaround, in FigJam you can also right-click on an image to ‘Copy as PNG’ > select ‘Transparent’ background which should not have any padding applied. Hope this helps!
Tricia
  • February 22, 2024
Yeah I was hoping to find a solution that would stay within the FigJam file, I tried exporting with transparent background but it’s still exporting with a border… though just a transparent one.
I want to share the FigJam file with people who are not Figma users, and I want them to be able to extract images directly from the FigJam file. Oh well, Thanks for the reply though.
Celine_
  • February 26, 2024
Thank you for your feedback Tricia! Unfortunately, we can’t at this moment. We’ll pass along your feedback to our team for consideration.
I’ve gone ahead and switched your topic as a feature request, so others in the community can vote up for the idea!
Dylan_Jones2
  • April 22, 2024
I take a screenthot, bring it into FigJam and be default it has a border. I dont want this. I expect to go to my preferences and uncheck a box that says “add border to image by default” or something along these lines.
Javier_Rincon
This is very odd behavior. Why does Figma add a border? The default should be to export an image as is.
Conrad_HyperCinema
Mega upvote for this.
D1111
  • October 1, 2024
Also agree, the border is an unnecessary addition.
Miles_Gregory
Hey Figma, please sort this out. The border is creating a crazy unnecessary step in my workflow. Miro doesn’t have this problem. Big upvote for this fix.
Tarver_Graham
Hi Celine – but why? This border is so tremendously irritating. What is it’s purpose? Is it a kind of dark pattern to encourage more Figma use? We’re already using Figma. We just want to be able to export from FigJam — without border, with original metadata. Is this too much to ask?
  • December 13, 2024
Hey @Tarver_Graham, sorry for the frustration!
Ultimately the team decided to default the border, because they felt that FigJam should by default help non-savvy users create boards that feel more aesthetically pleasing. The team felt that borders make an image dropped into FigJam feel more curated and less plain.
That said, we should auto-respect your last option for image borders, meaning if you’ve turned it off once, it should save your preference. Can you please confirm whether or not that’s the case?
Tarver_Graham
Thanks for the response Celine. I’m really asking about export here. I can set “transparent” as a border style for exported images, but why not a “none” option? I appreciate that I can copy as PNG, open a Figma file and export from there … but again, why enforce the work around just to achieve a basic clean image export?
The other thing we’re really missing—and the reason we’re still using Miro—is retained meta data. For context, a key use case for us is collecting and collaborating on AI-generated images and storyboards. Meta-data on images includes critical prompt info. When that’s striped out, it dramatically reduces the utility for us.
Tappy_David_J
+1 to this
If i ‘export selection’ it should just export the selection. The addition of adding a very large border seems strange, i can’t understand why you would add it?
At least have a check box to apply border or not in the export selection dialog
Please consider looking at this
Ana_Pirenjak
  • September 12, 2025
+1 for this to be an option when exporting selection.
Honestly, it doesn’t even look “aesthetically pleasing”. It looks more like a bug. There should at least be a checkbox to remove/apply this border as others mentioned.
Sam2026
  • January 19, 2026
This is very odd behavior. The default should be without a border and if people want a border than you can give them an option to do so. Why hasn’t this been resolved yet and when will it be resolved? It’s very annoying..
