Dev Mode: Compose code language not showing gradient info
Rob_Marquardt
I have a frame with two gradients with multiple stops in each. In Dev Mode with the code set to SwiftUI, it shows the two LinearGradients with an array of stops for each. When I change the code to Compose, I get no mention of the gradients, just a couple lines for a Column arrangement and then literally // Child views.
This wasn’t the case prior to Dev Mode and now I’m having to ask my Android engineer to translate from the Swift values. Is this something that’s just not wired up yet?
(There’s a FigJam · Bugs tag but no Figma · Bugs?)
Rob_Marquardt
  • 13 replies
  • June 26, 2023
Example screenshots
Our team have encountered the same issue
Vianney_BERNET
Same here, it’s not showing the CSS code of linear-gradient anymore (for gradient text for instance).
Adriano_Varlotta
Not showing to me as well
our team is experiencing the same issue with dev mode. would love to have this fixed as it’s necessary for our dev team to have access to this code!
Alex_Stoian
  • 5 replies
  • November 29, 2024
same here, the team has to match hex codes to our tokens manually and it’s quite annoying.
Figma design using local variables:
Dev mode shows only hex codes:
