Creating a weight scale prototype
Hi, I am trying to create a weighing scale prototype. I am attaching a screenshot for reference. I want the number to change as a I drag the weighing scale below. I tried giving number variable to it and gave a drag interaction to the scale but it’s increasing unevenly not smoothly.
  • 2545 replies
  • May 13, 2024
Thanks for reaching out! If you set “on-drag” animation, I guess it should work perfectly. Could you share the screen recordings or file link with us so we can check the behavior?
Additionally, I think this YouTube looks helpful even thought it’s not using Variables:
Numbers Counter Animation Figma tutorial | Numbers Slider animation|Numbers Counter Animation Figma tutorial | Numbers Slider animation
I also hope other community members share their insights as well!
Looking forward to hearing from you.
  • 4 replies
  • May 13, 2024
I don’t want the numbers to change as a scroll.
Figma – 13 May 24
This is the file link
  • 2545 replies
  • May 24, 2024
My apologies for the delayed response. Have you already found a solution?
From what I observed in the prototype, one reason for the uneven increase might be that the variable increments by 0.1 each time you drag the layer. A possible solution could be to create frames connected by smart animate instead of using variables. I know it’s not a perfect solution.
I also hope other community members can join this thread and share their insights for a better solution. I’m curious as well.
  • 4 replies
  • May 24, 2024
But if I do it like that. Then for even 1 kg increase I will have to make a lot of frames.
