Copy & Paste option doesn’t seem to work
When I try to copy and paste a frame, Figma only copies and pastes the text in the frame.
When I try to copy and paste an image, an icon etc. It simply doesn’t paste anything.
The copy & paste function was working perfectly and all of a sudden it stopped working.
ksn
  • 1711 replies
  • April 12, 2024
Hi - can you provide more info so I can look into this?
You had another topic that mentioned an iOS device. Is this the only place you’re having this issue?
Hey, yes, I only have this issue on my IPad Pro. I use Figma on browser on IPad, but I can’t copy & paste after the last update.
I think it is about IOS devices paste permits, but I can’t find any setting about permits to fix this problem.
ksn
  • 1711 replies
  • April 15, 2024
Got it - I can’t speak to why it isn’t working anymore, but I do know that Figma on Mobile is not fully supported at this time. I do see you have a ticket filed with support, so the team should be able to provide you additional info.
Natalie_Yackoby
Hey, I have a similar problem on a desktop - the copy paste creates a huge mess, when I try to paste into a different frame or a file. Seems like the layers order gets messed up as well as destinations between the components. Any ideas what can be done?
ksn
  • 1711 replies
  • May 1, 2024
@Natalie_Yackoby Could you drop a screen recording of what happens when you copy + paste in both frames and files?
Also, is this happening when using both shortcuts AND right-click to copy + paste? You mentioned you’re on desktop, but just to make sure: are you using the desktop app, or the web version of Figma? Can you let me know if it’s happening on both?
Thank you!
GAZAL_ROONGTA
I’m facing the same issue. Tried to take a frame (it has its own auto layout sets, instances, components etc) from one of a free community template -and tried to put it on one of my other Figma files, and all it would do is copy paste the text in the frame, and not the actual design. It’s kind of really urgent - and I would really appreciate if someone could give me a solution for this.
Thanks.
Rafael_G
  • September 30, 2024
marcus.jansson
I cannot grab a simple image/rectangle/etc, copy and paste it. Nothing happens.
ksn
  • 1711 replies
  • October 18, 2024
@marcus.jansson Can you give me some details?
Is this happening on the desktop app, Figma on the web, or both?
If on the app, can you try uninstalling/reinstalling the app to see if it clears up?
if it’s only on the website, can you clear cache/cookies for Figma specifically, restart your computer, and try again?
Let me know how that goes.
marcus.jansson
Well, it happened on the web. Cleaning cache alone didn’t do the trick, but restarting the computer did. Since then everything has worked like a charm, as it normally does.
Jups
  • April 3, 2025
Hi, I’ve been having the same problem these days. I’ve restarted my laptop, then turned it off and back on and the cleared the cache. ​@ksn (or anyone else) Do you have perhaps other suggestions, please? Cheers
  • 2545 replies
  • April 10, 2025
Hello ​@Jups
I'm Toku, and I work with @ksn on the same team. I'm trying to reproduce the issue on my end, but I haven't been able to replicate it yet. Could you please provide more detailed steps to reproduce the problem? Also, does this occur in both the Desktop app and the browser version?
It seems like this might be a different issue, but since we've received a different report about copy/paste problems, any additional details you can share would be really helpful.
Thanks for your patience!
Bamba
  • June 4, 2025
So I was having the same issue and it turned out that Clipboard access to Figma had been blocked. I had to go into my browser settings and allow The Clipboard Permission for Figma. If you go to your browser settings and search clipboard you should find the permissions.
tajraturkovic
I know this is posted 1y ago but for anyone reading I found my solution: go to settings, website permissions,  toggle off clipboard (this actually disables the "ask before" thing that is actually messing with your work even though you see nothing pop up) I already assume figma is on your allowed list as it should be.
