Constraint properties updating across component instances
  • August 14, 2024
  • 5 replies
  • 95 views
Maddy_Sabulis
My constraint properties aren’t updating across my component instances after I edit the parent component. I’ve ensured that my instances are inside their respective frames.
Is there something I’m doing wrong or is this something to do with an update? I would love it if the constraint properties applied to the child components when I edit the parent!
  • Figmate
  • 2165 replies
  • August 16, 2024
Hey @Maddy_Sabulis, Thanks for getting in touch about this. I totally get how helpful it would be to edit the main component constrains and have those changes reflected in the instances.
I tested it out on my end and observed the same behavior you mentioned. I’m not certain if this is intentional or if it resulted from an update, so I’ll be reaching out to our internal team.
I’ll keep you posted once I have more information.
Thanks once again for reaching out!
  • Figmate
  • 2165 replies
  • August 20, 2024
Hi @Maddy_Sabulis, we are actively investigating this issue.
Could you kindly create a video recording of the problem, showing the entire Figma screen including both the left and right-hand panels? Also, if you could share the link to the affected file, it would greatly help us in further analyzing the situation.
Thank you for your assistance!
  • Figmate
  • 2165 replies
  • August 21, 2024
Hello @Maddy_Sabulis, we’ve looked into this matter and it appears that this behavior is intentional.
However, I can see why you may be confused and I believe it would be a beneficial suggestion. Therefore, I’ve relocated your post to the “Share an idea” section, where other members of the community can vote on it.
Furthermore, I have also brought your case to the attention of our team for future consideration.
Please note that we cannot guarantee that it will be implemented. Meanwhile, please keep an eye on our Release notes and blog.
Thank you for providing such valuable feedback!
Shaimoom_Newaz
@Junko3 Why is this behavior intentional?
  • Figmate
  • 2165 replies
  • December 5, 2024
Thank you for reaching out with your question.
As things stand, it is set up in that particular way, and we understand it might not entirely match what you were hoping for.
Please be assured that I’ve already shared this feedback from our community with our team for future consideration. Your input is greatly appreciated and helps us grow and evolve.
Thank you for being a part of our community and for your valuable contribution.
