Conditional interaction and disable scroll position (go to top of page)
Hello friends,
I am using a conditional interaction to set a variable which turns off a layer. After this occurs, I would like the page to scroll up or return to the top.
In looking this up, I’ve found there is a “disable the scroll position” checkbox when prototyping a link between frames.
Is there something similar for my situation?
Thank you.
Gayani_S
  • 2159 replies
  • January 3, 2024
Hey Doug, I found a YouTube tutorial showing you how to set this interaction with a header. Let me know if this is want you’re searching.
Hi,
Thank you. It is close and I did try adding two interactions. One to set my variable and another to scroll to the top of the page, however, Figma does not seem to run them both.
Because I am setting a variable through an interaction, Figma has no idea that I want to scroll to the top of the page, which is completely understandable.
It’s almost like I need a programmatic method of scrolling to the top of the page…
Anyone have any other suggestions?
Thank you.
Random thought…
I did take a look, but a frame scroll position property would do the trick. With that I could assign a variable value, but I don’t see one.
If anyone encounters the same issue, this thread will help.
Multiple Click Interaction Events - Ask the community - Figma Community Forum
