Compress exported PDF file
  • September 5, 2023
  • 4 replies
  • 1747 views
Yirou_Choo
I suggest having this feature in Figma since we are on a paid plan. Especially when we have so many frames/screens to be exported (eg. 170+) it’s a really huge filesize.
And it’s not allowed to use an external PDF compressor platform when our projects are confidential.
So far, I can only convert the frames into individual PNGs/JPGs, replace the frames with these image files, and export them into PDF. This is so time-consuming and troublesome.
Miek
  • 26 replies
  • September 5, 2023
You can use our plugin MKIFPdf,
Figma
even if it can not yet reproduce all the possibilities of Figma to 100%.
But it should be enough for many cases.
The generation is 100% on your device!
While Figma doesn’t currently offer built-in PDF compression for paid plans, here are some alternative solutions you might consider:
1. Utilize Figma plugins:
  • Pitch Deck: This plugin allows you to compress large PDF presentations while maintaining quality. You can set the desired DPI (dots per inch) to balance resolution and file size.
  • Compress.app: This plugin integrates with the online compression service of the same name, letting you directly compress exported PDFs within Figma.
2. Explore Third-party Tools (with caution):
  • External compression services: If your Figma files contain sensitive information, exercise caution. Use reputable services with strong security measures and avoid uploading entire designs. Consider compressing only exported PDFs after removing confidential elements.
  • Desktop compression software: Tools like 7-Zip or Adobe Acrobat Pro allow PDF compression while offering better control over confidentiality compared to online services.
3. Optimize your Figma file:
  • Reduce image sizes: Replace raster images with vector versions whenever possible. Consider using lower resolutions for non-critical elements.
  • Minimize text layers: Convert text to outlines if the formatting isn’t crucial.
  • Remove unused assets and frames: Clean up your design to exclude unnecessary elements.
4. Advocate for the feature:
  • Let Figma know about your needs through their feedback channels. They might prioritize developing a built-in compression feature if there’s enough demand from paying users.
PDFsail
  • July 2, 2025
PDFsail
  • July 2, 2025
I’ve used Compress PDF online. I have been using the same PDF quality with a smaller file size for a while. I will keep using it for my occasional PDF sharing needs. I thought the TinyImage plugin would be a good solution. However, after the trial, it doesn’t make sense for me to keep using it. This is true for PDFs and other formats, as they export smaller.
It would be best if Figma just had this built in, for every export format including PDF.
Why would anyone intentionally export files that are several times larger than what’s possible to output?
