Component Variable - Carousel
  • August 27, 2024
  • 15 views
Annahi_Paez
Hello!
I’m facing an issue with changing images in a carousel component in Figma. The main component has four different variables, each with placeholder images. When I try to update these images in the component instance, only the image corresponding to the active property gets updated, while the other images remain the same as in the original main component.
For example, if I’m on Image 1 in the property, only Image 1 updates to the new image, but Images 2-4 stay the same as in the main component. If I switch to Image 2, only Image 2 updates, and Images 1, 3, and 4 revert to the main component’s placeholders.
Any insights on resolving this would be much appreciated!
