Component is distorting images when applied
Vinicius_Muller
I’m building a component that includes several logos, each of which is its own component. When I’m in the process of creating it, everything appears correctly, but when I apply the component for use, the logos end up distorted. What could be causing this?
Celine_
  • 3733 replies
  • February 8, 2024
Hi there! Sorry to hear you are having issue with components.
Can you please try the command ‘Regenerate all instances (slow)’ in the file with the issue (found in the Main Menu in the top left, and then click “Quick Actions” and type the command and click this) and check if the instances then look correct?
If the issue still persists, please reach out directly to the support team so they can investigate further: here
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com
Lee_PB
  • April 8, 2024
I have the same problem 😦
Any solutions yet?
ksn
  • 1731 replies
  • April 8, 2024
Hey @Lee_PB – just to make sure: did you try using the ‘Regenerate all instances (slow)’ command (found in the Main Menu in the top left, and then click “Quick Actions” and type the command and click this) in the impacted design file, and see if the instances are then corrected?
Vinicius_Muller
The option ‘Regenerating all instances as slow’ didn’t work for me. I’ve had to resort to working manually, detaching the instance to place the logo manually through the auto-layout frame. Still haven’t found a solution 🥲
ksn
  • 1731 replies
  • April 9, 2024
Got it - iirc, the original problem that started this topic ended up needing support intervention.
I’d recommend you also reach out to support now for further help – I’m not sure if this is a resurrection or sign this didn’t get fixed for everyone. You can reach out by emailing support@figma.com, or by filling out this form: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
^^ They can take a look at the file/library.
