Component instances with text style override resets when using property panel
  • August 6, 2024
  • 7 replies
  • 230 views
Feng
After removing bold/underline styles in our design system (due to the text style override update), we’ve noticed an issue:
In a main component with a non-bold text style:
  1. Apply bold formatting and a text property.
  2. Create an instance.
  3. Changing text via the property panel resets bold formatting.
However, editing text on the canvas preserves the bold weight.
Is this bug being tracked or expected?
Feng
  • August 22, 2024
Can someone from Figma file this bug, or please let me know if this is expected? It’s a blocker for us from removing bold text styles in our DS.
demian
  • 5 replies
  • August 23, 2024
Also seeing this bug!!!
demian
  • 5 replies
  • August 30, 2024
An update: I have opened a request with Figma support. They were able to reproduce the problem and have escalated it to the engineering team for further investigation. As soon as they provide an update, I will post it here.
David_Simpson
  • 14 replies
  • September 3, 2024
Hi, i’m seeing the exact same issue where using the property panel to edit text in an instance removes underline.
Mark77
  • September 10, 2024
Having the same issue, bold or underlined text losing the styling when using the property panel to edit the text, hope the team can fix this bug otherwise it looks like we’re adding more styles to the design system
demian
  • 5 replies
  • October 9, 2024
Hello, here’s an update: Figma sent me a response a while ago.
Hi Demian,
Our engineering team have also confirmed that this is a bug - however I want to be transparent with you that this will not have an immediate resolution as we need more time to investigate this.
For now as a workaround, changing the weight instead via the style picker in the Design Panel, should avoid this issue:
While I can’t promise a quick fix, please know that our engineering team is aware of the issue and will work towards finding a solution in the future. We appreciate your understanding and patience in this matter.
If you have any follow up questions or want to check on progress, just reply here and the conversation will re-open so we can give you a hand.
Thanks again for your help here and for your patience while the team continues investigating.
Best Regards,
Technical Quality Specialist
Figma
Thomas_Dawborn
Any fix for this yet?
