Comments stick to object instead of position on layout
fred_k
The comments feature is very handy amongst the colleagues.
It would be nice if the comments bubbles would stick to the object instead of sticking to the position within the frame.
Since we are moving stuff around ( adding or subtracting elements ) the comments made should stick to the proper parts of the design.
Otherwise, when we move things around, the comments don’t make sense anymore because they do not relate to the object’s new position.
Josh
  • Former Community Manager
  • 1019 replies
  • February 5, 2021
Thanks for sharing this idea @fred_k. I agree that being able to pin comments to any object/layer would be helpful!
fred_k
  • February 8, 2021
Thank you Josh! How is your process working. I am curious to know what are the feature requests that are making the cut. Is it a matter of voting?
  • 4707 replies
  • February 9, 2021
fred_k
  • February 9, 2021
Thank you!
Jesper_Hansen
Came here with this idea too. Would be very useful as designs constantly change. things move around and discussions often revolve around a specific element, section, etc. If I delete an element with a comment attached to it I think it would make sense to just have the comment unpinned.
Shi_Min_Lee
Curious! Has any changes been made to this yet? Great feedback btw, same thought with you on this! 😊
Ruben
  • July 2, 2021
Yes this would be very helpful. Three thumbs up!
delia_tee
  • 4 replies
  • November 10, 2021
I think the use cases vary. I would actually appreciate being able to pick between pinning a comment to an item vs adding a general comment vs a comment placed at a certain position in the frame.
Aleksandra8
Hello! Is it possible to add this feature? I suppose it worked in the past, but now it’s not possible and a bit annoying.
QiaoZhang
Any updates? Can’t believe this feature is missing from a newbie-as-I-do standpoint…
Bhuvanesh_Patrick
Really do need this. And it’s strange because if an object is NOT in a frame, the comment will stick to it, but you can’t pin comments to objects in frames. But I can see an issues like a comment being pinned to a group and then the group being ungrouped later, so I realize this is a hard problem overall. Hope this can be figured out!
Spyros_Potidis
On a second level, have comment categories with view/ hide option.
For example,
  1. I can create a wireframe design and me, or a collaborator, move it/ copy-paste it anywhere and comments stick with it.
  2. Moreover, I want to create and distinct comments for the development team, separated from the comment to the CX team, other comments for the UX Writing and copies team, and instruction for UI team, so every team may be able to hide unnecessary comments and instructions/ help the async. communication between teams.
Morten_Hoffmann
Still need this!
Please make this feature @Figma_Support
@Figma_Support agreed, that feature would be really helpful!
I have to move my comments around with the design a lot. Very annoying!
Axel_Estrada
Sticky comments - next little big update PLEASE! 🙏
It’s extremely frustrating that comments do not follow elements on the stage. If the UI/UX of a mockup is rearranged it gets very confusing to follow the comment threads for further updates as comments are fixed elements.
  • Comments should be fixed relative to elements on your layers and not absolutely positioned.
  • If a layer with comments gets deleting it should prompt a dialog window to delete (or fix the position) the comments with the layer.
Extremely required feature. Really.
Tips:
  • Why not position comments same way as any other layers on canva?
  • It is also good idea to have it on the objects (layers) list on the right, so we can see on which object it is positioned
  • it should always have set flag “stack-positioning-toggle”, this way it never will affect to other objects positions.
Laurens1
  • August 20, 2024
Let me tell you right now, I’m doing the wireframes and copywriting for a fairly technical website (civil engineering stuff) and my client is very ardent in his feedback. In the sense that he’s kind of writing everything himself at this point. For the record, he’s trying to be helpful, not being a dick. He’s an engineer so go figure.
Anyway, the problem is that, in Figma, I currently have 193 comments scattered around four wireframes. You can imagine as soon as I move stuff around, a puzzle unfolds where I have to figure out which comment related to what piece of text, title, graphic,… Why can’t comments stick to the pixel of the layer they were pasted on instead of just straight canvas coordinates? How would that ever be useful anyway?
This sucks so bad it’s honestly mind-boggling.
SomethingFishy
Is this yet another QOL improvement destined to gather dust for years? It’s a little shocking that no one saw the issue in NOT anchoring comments to objects/elements. I guess it would present a challenge if an object was deleted, but it seems way worse trying to navigate comments on a constantly evolving design.
Thomas Schrobiltgen
UP
This needs to be improved ASAP
Let’s hope this pain point is part of Figma’s roadmap as we can clearly see the issue has been reported 4 years ago and is still relevant to this day.
George_Simons
This totally would have been done before the acquisition by Adobe.
Sticky comments would have been way more helpful than the recent UI overhaul.
Sticky comments please, please, please.
