Can't Use Nested Components to Change State in Prototype
  • August 18, 2021
  • 1260 views
Michael4
Going to do my best to explain this issue succinctly. Please let me know if you need more detail.
In some of my mockups, I have a side panel with tabbed navigation. I set up the different tabs as variants and included the tabbed navigation as part of each variant. The tabs are a component from our design system.
My desired behavior is:
  1. User clicks on a tab in the prototype.
  2. Panel changes to the correct variant.
When I try to set this up, it will only work if I use ‘Detach instance’ on the tabs to detach them from the parent component. This isn’t ideal, as I’d prefer they continue to inherit changes to the design system.
Michael
  • September 17, 2021
