Hi I’m trying to potentially make interactions between two assets (if that’s possible). I have a drop down menu where you select from a number from 1-3. I would like there to be a interaction between the number you select in the drop down menu to an asset that will display the number you select in text format. the context is: someone will select the number to represent how many vacant positions we have and then this number will be displayed in text format.
Can I create interactions between two assets
Best answer by Nate_G
Yes, you can do this using a number variable. When you select an option from the dropdown you set the number variable equal to the selected option’s number. Then you assign a text field to that number variable and it will change accordingly.
→ View Prototype
→ Get Example File
