Auto layout clipping content
  • November 7, 2021
  • 4 replies
  • 4720 views
Rachel_Sweet
I am trying to create a form, where I’m using auto-layout to stack frames (each frame is a different field with interactions that change the height of the frame). Some of these elements are dropdowns, and I am unchecking “Clip content” so that the dropdown can appear correctly.
The problem is when I use auto-layout to stack the frames, the dropdowns are getting cut off. It appears that this is because the top frames are below the bottom frames in the layers, but I can’t seem to change this to make it work.
Best answer by tank666
Yes, this is because the layers in Auto Layout are ordered the other way around. There are several ways to fix:
  • Don’t use Auto Layout to combine these objects;
  • Or rotate this Auto Layout 180° and then place your objects in it.
You can also vote for this idea: Layer order in Auto-Layout
  • 4870 replies
  • November 7, 2021
Rachel_Sweet
Wow, mind blown by that 180 trick 🤯
That works great! Thank you!
Israr_Choudhry
That’s a really good work around! thanks, I’ll try this for sure 🙂
  • December 8, 2021
