Jason_Longhurst
April 19, 2024
API endpoint to GET a list of team ids
We need a way in the REST API to get a list of Team IDs.
A previous post (Suggestion: API endpoint for :team_id) was moved to ‘share an idea’ and then marked as solved, so I’m reposting sans solution, in hopes that we can get some votes.
With the new library analytics API, this feels more relevant than ever.
I want my users to pick the team their library is in from a list, and then pick the library file from a list of files. Trying to get end users to figure out how to get the library file ID is needlessly complicated to start taking advantage of the new API, when I could set up a system to let them pick it from a list.
Almost all of the endpoints require a Team ID… (or require a file ID, the list of which requires a project ID, which requires a Team ID… etc.) So adding a Team API would unlock improved usability for almost every other REST API endpoint.
Let’s make it happen.
Sean_Taylor
May 28, 2024
+1 it’s really difficult to use the API without being able to get team IDs. Fine for really small orgs, but anything involving dozens of teams makes grabbing IDs from URL an awful solution.
cya2025
+1, we encounter the same issue as well. Working in a multi-national (and continue growing!) company, across different regions and timezone. It’s essential to have a way to get all team_ids under the same company account.
laurenz.honauer
Same here, I work in an environment with many users coming together from different companies. We would need all sort of API capabilities to fit our usecases.
Full CRUD access via API on Teams, Projects etc would be highly appreciated
Jan Zunec
+1, we do require an option to toggle between the teams right through the API, and it’s really difficult as now we must input all the team IDs manually and also manually add any new teams.
Rob Zimmelman
we require the ability to create teams via the api as well as create projects for a team and other write options.  the product seems a bit unusable for large teams due to these limitations.
