Allow us to add gifs on figma slides
We use a lot of gifs in our slides and you can’t insert the link to a gif in Figma slides.
Frederic_Fornini
Hello @Ashani_Escoffery it is possible to add Gifs.
(I tried with a simple drag and drop and previewed it before this message).
Enjoy.
When you say drag and drop where did you drag from? I was referring to adding gifs through the web platform Giphy (which gives you links to add to presentation slides)
Frederic_Fornini
From my finder. If you want to add links from any url it won’t work.
And i’m sorry i did not understand at first that you were talking about an external link (as a URL).
May be changing the name of the topic would clarify you request.
Regards
Kate38
  • 5 replies
  • June 28, 2024
You can upload using Giphy link by
  1. copy gif’s link,
  2. click on “Image/Video” icon in Figma to trigger Upload window
  3. insert link into “File Name” entry field.
It will be downloaded to your PC automatically (you can delete it) and it’ll be visible and static on slide.
When you enter Preview Mode, GIF will be animated.
Frederic_Fornini
@Kate38
I can’t seem to repeat the same steps.
Would you be so kind to upload a screenshot ?
Kate38
  • 5 replies
  • June 28, 2024
Of course! 😀 @Frederic_Fornini
At first you should choose a gif from Giphy and copy its link.
giphy share
Then you can click on Image icon or press Ctrl+Shift+K
In upload window will be empty field with File name title. Paste copied link from Giphy there and press Open button. (Mine is in Russian on the screenshot but it’s the same in all languages)
Click on the slide and gif will be there. Works with any images from any website if you have the link to them
This is awesome, thank you very much!
Katelyn_Ernesto
My team likes to add animated GIFS to their google slide decks, and they would be more likely to convert if we can have them in Figma slides.
Lauren27
  • July 12, 2024
This is not what the user was asking for (or at least not what I was hoping to accomplish.
Yiran_Ma
  • August 24, 2024
Glad we can add gifs, however they don’t auto play unless switched to presentation mode. The majority of the times viewers consume the content on the slide/grid view and not in the presentation mode, and can easily miss out on the great design contents we want to showcase through the animated gifs. This has become a major blocker for the team to make the switch from google slides 😦
angela21
  • 4 replies
  • September 17, 2024
Hi, how do you do this on a mac? There is no entry field.
  • 4710 replies
Download the gif and put it in the slides
angela21
  • 4 replies
This did not work, checked in present mode as well.
  • 4710 replies
What do you mean by “didn’t work”? What exactly did you do and what results are you seeing?
angela21
  • 4 replies
I saved the gif to my desktop, tried dragging it into the Figma slides doc, also tried adding via add image. Both showed a static image of the gifs but neither actually played the gif in presentation mode. I saved multiple different gifs to see if it was an issue with a specific gif but none worked for me.
Valeska_Bachauer1
I have the same experience. Thank you for clarifying.
Kim_van_den_Hout
Did you solve it? I also don’t get an insert field. Drag and drop, I only get a still of my Giphy in it. Or by saving it and inserting it at video… I really don’t know how to solve…
angela21
  • 4 replies
  • October 18, 2024
Nope was never solved 😞
Sasha_Pronina
Folks, on Mac replace file’s name with that Giphy link described above and then insert the img into the deck, it will be animated when in presentation mode
Ines_Mir
  • November 18, 2024
It still doesn’t work on mac. Changing the file name to the link is not allowed on my mac.
Did anyone found a solution?
Antoine_Sochat
Same here, it doesn’t work on my Mac. And uploading a downloaded gif from my computer doesn’t work either, it’s just an image that doesn’t get animated even in presentation mode
