Adjustable/Custom-sized Figma Slides
Mitchell_Opatowsky
I just want to adjust the page settings for each page “frame” so to speak so I can make it wider. It’s not clear that this is possible.
Yes please, would love this feature
Gabriela_Prattingerova
This feature would be useful!
  • Figmate
  • 2091 replies
  • June 28, 2024
Hi there, Thanks for sharing your thoughts about Figma Slides!
Your feedback will be shared with our internal team for their consideration. If you have already commented on this post, please remember to vote for it at the 🔝 We use votes to measure the community’s interest.
If there are others in our community who have a similar idea, please demonstrate your support by voting/leaving a comment.
Thank you for sharing your valuable input!
David_Leman
  • June 28, 2024
Would be great to use Slides also to create materials and export as PDFs in different sizes. For example A4 in portrait and landscape.
And in export-mode also be able to choose which frames/slides to export to a PDF (couldn’t see that option atm).
Slides are gonna be great!!
Joe_Williams
Yer, it is 1920 * 1080, which is half my monitor screen.
There seems to be a slight hack. If you go into Design Mode. Select the frame and you’ll see the layout is greyed out where you can see the dimensions 1920 * 1080. However, if you hold the option key and drag right you can make it wider. Although it’s clearly not design to do this as the formatting looks weird and is muted.
Frederic_Fornini
Hello,
We make presentations on various screen size.
Dimensions are very important and the default 1920x1080 is quite limiting.
Secondly by default we can’t change those dimensions like we do in a Figma design frame.
I first have to create a frame inside the layout and then resize my slide (or use the sliders, which is not really precise or practical).
Once i’ve done this, overflowing elements are dimmed and the presentation never really fits the artboard size that i want.
I also see the main artboard in the back with those disturbing rounded corners
I want to use slides in an immersive / interactive room and need to set a costum size for the screen - is this possiable?
Rafael_Oli
Guys, I finally found a workaround for this:
  • Create a clean slide with nothing inside
  • Create only a pure rectangle with the ratio of your screen presentation
  • Position x=0 and y=0
  • Scale to width 1920 (keeping the height linked in proportion)
  • Hit the resize to fit button on the right side (right after the Layout label)
  • Press play in the presentation
  • Voilá
/ The slide thumbs will be deformed and broken. Also, the canvas in design/slide mode will not change, making a part of your layout bleed out of the frame.
But in presentation mode, it will work perfectly. 👹
Manvydas2
  • 4 replies
  • August 2, 2024
Please allow slide canvas to be set in whatever dimensions needed. 1920x1080 is incredibly limiting!
Roland_Andrei_Cristi
It’s crazy that this slide canvas resize feature is not even included in the initial version, this is a low-key must have feature! I really want to use this slides but I can’t right now. Please add this!
Frederic_Fornini
I’m perplex about seeing that feature anytime soon, since Figma is promoting the ability to change a template layout with another in an instant (if i got it right).
What i don’t understand :
  • I don’t think people using ppt, keynote… is not the primary target here, so…
  • …If the aim is to target designers who, i hope, know what they’re doing and are the people doing the presentations in a lot of agencies for themselves or creating a template for a client.
    Well, setting a canvas size by default, is already huge design choice.
    No control over it, is not only a frustration, but also a very limiting factor for adoption.
I would love to make presentations in Figma then pass it to my clients so they can use it as a template without a huge monthly fee.
The reasons why I make my presentations in Figma are that I have this freedom like nowhere else. Free canvas size, multiple Grids, easy text styles, reusable components, transitions, variables, responsive design, everything is already there.
The only really painstaking task is to keep all the navigation elements in check, be sure to have arrow keys going back and forward. Then when we add a page, we have to move everything around.
Jon17
  • August 8, 2024
My team often makes portrait presentations that are more suited to viewing on a phone. Would be great to have custom sizing to enable this.
Christian_Gruber
Would it be possible to do 4:3 slides? I have the feeling that 4:3 is the perfect format for desktop but also portrait mobile uses. 16:9 gets very small.
Ted6
  • September 4, 2024
Please add the function to customise the size of the Slides. For example the ability to make portrait PDFs with Figma Slides, instead of the current limitation of 1920 x 1080
Andrea31
  • September 16, 2024
+1 would be great to resize slides
Xenia_Turubanova
My 2 cents for the slides resizing 👋
skylar1
  • September 26, 2024
I’m making tutorials with Slides, and the primary audience/use of these tutorials is on mobile. vertical or, better yet, custom ratios would be of great interest!
Rachael_Duranti1
Agreed, this would be super useful for making mobile-based brochures etc.
Carter
  • November 25, 2024
Yes, i would also like this. I need to make some images for publishing a Chrome Extension to the Chrome Web Store. They need 1280x800 images. The default/unchangeable aspect ratio that Figma offers is not the same proportions as 1280x800.
Jakub_Linowski
Hi Figma Team. Any updates on this? Would love to set the Figma Slides page size to say 2560 x 1440. Please help.
Ingchhorng_MRA
Super useful to have this feature. Same as how you can select frame size in Figma, in slide it’s necessary too. There’re many circumstances where the presentation is not always in the current size that is set. Please enable this. Thanks
Antoine_Sochat
I confirm that would be helpful to resize as we see fit.
Among others, the square format is more and more used in web embed presentations - Linkedin uses it in carousels for example.
  • 11 replies
  • March 12, 2025
Just came here hoping to find an answer — would also +1 this
Ioana Surdu-Bob
Hi +1 from my side too. We have square and a4 presentations that we could move to slides.
Jake_Brewer
  • March 19, 2025
🤚🏼 Another vote for custom slide sizes!
