Adjust Letter Spacing Shortcut doesn't work
Adjust Letter Spacing Shortcut doesn’t work. Even when I press the shortcut, it isn’t enabled.
Any ideas?
Hi @AresVentures I’ve tested this on my end in both the browser and desktop app was was able to use the keyboard shortcut. If you are seeing this issue in the browser can you check to see if you have any browser extensions enabled which might conflict? Also maybe check to see if you have any other programs which use the same keyboard shortcut running.
I’m having the same issue.
Were you able to fix it?
Thank you in advance.
Hey @Sandra_SF,
Have you tried Ryan’s suggestions above yet? :point_up_2:
