A shortcut to open the "Local variables" window
Hello everyone!
I think having a shortcut to open/close the local variables would be very helpful.
For example in cases where I’m prototyping and need to access the local variables to ensure the accuracy of the variable names or values that I’m assigning in the interactions.
Currently, if I want to do this, I have to switch between the prototype panel to the design panel in order to open the local variables, check them and then go back to prototype.
Note:
I am aware that it is possible to keep the local variables window open, but this often leads to numerous bugs in the prototype. For example, when it is open, I am unable to drag the prototype interactions to reorder them.
Excellent idea! I also find it very annoying that if you want to publish updates the window automatically closes and you need to reopen it again afterwards…
Excellent idea, Lucas! I think it would be a shortcut that would help us a lot when prototyping. It’s true what you say about leaving the variables window open causing many bugs in the prototype. I really hope they can make an improvement on this
This is a great idea. I’m trying to debug something right now, and I keep having to switch between panels.
