Thomas_Nabelek
Feb 27, 2024 5:56 PM UTC
Use inverse of Boolean variable to show/hide layer
This has been mentioned here:
I am looking for the availability to HIDE a layer when a Boolean variable is TRUE and SHOW it when it is FALSE. So, the inverse of the default/current behavior. I want to do this without using components.
Use case: When a variable is true, show one frame. When that same variable is false, show a different frame.
I can get basically this by using two different variables:
but it would be more convenient to be able to do it with just one. Just give me a Boolean toggle when the variable is used to say if the variable should be inverted or not.
Aryk Grosz
Jan 14, 2026 3:01 AM UTC
+1
Christian_Franck
Jan 18, 2026 3:09 PM UTC
Also need this...
Cory Chung
Jan 21, 2026 1:00 AM UTC
+1
Still need this as of 2026...
Mark_Chitty
Feb 10, 2026 5:00 PM UTC
+1 Still need this. Being able to set a variable value to an expression would suffice.
Enrique_Herrero
Feb 20, 2026 7:46 AM UTC
+1 This would simplify a lot of conditional designs hugely.
artichokes
Feb 23, 2026 10:23 AM UTC
+1
It’s currently nothing more than a show/hide layer toggle. I want to control more, for example buttons that are icon only. Now I need 2 booleans for 1 function.
Art_Klepchukov
Mar 12, 2026 9:36 PM UTC
After 2 years (!), is this enough feedback Figma?
cc: ​@y_toku
DJPat
Apr 23, 2026 12:58 PM UTC
+1
dsp
May 13, 2026 1:22 PM UTC
This is the biggest blocker in our orgs design workflow right now. I don’t need AI features, I need this.
Smith_Samuel_D
May 20, 2026 1:53 PM UTC
Tying other posts with the same request into this:
