gimaf
Oct 21, 2024 9:57 AM UTC
Typography variables - Bind a variable to a specific text style
Use case
I have a button component which for different colors we use different text styles (one is bold the other is regular).
Solution
It would be great if I could just add to the button variables table a String field where I say which style to use based on the mode and bind that String to the text style of the label.
Pavel_Kiselev
Power Member
Oct 21, 2024 11:13 AM UTC
Make a text label component, give it few variants. Place that text label component inside the button and bound style variable to the text label instance. In theory this should do the trick for you
gimaf
gimafAuthor
Oct 21, 2024 12:44 PM UTC
I thought about that, but it would be better in my opinion if we could use variables instead: less headaches, less components, more consistency overall 🙂
in the mean time, the trick you suggested seems to work, thank you!
