evgenypyvovarov
May 18, 2023 5:58 PM UTC
Stop automatically adding FigmaAgent to Login Items
I don’t use Figma all the time, I don’t want it to run anything on startup.
It’s frustrating to manually remove Figma from Login Items, since it automatically adds itself there again.
It would be nice to have at least an option to disable it in settings, or even better - remove that functionality at all, since it’s not user friendly. I want control over what and when the apps do at my workstation.
P.S. If it’s needed for updates check - I’m more than okay to update on app start
Pinned Reply By djv
Hey @Josh47, sorry for the frustration!
The FigmaAgent starts itself for font access & to allow you access to any Figma links without having to log in. If you don’t need either of those, you can force quit Activity Monitor, remove System Preferences > Users & Groups > Login Items
Then, delete ~/Library/Application Support/Figma/FigmaAgent.app & /Applications/Figma.app/Contents/Library/FigmaAgent.app
If you’re still getting the FigmaAgent on restart then you might have a corrupt .plist file. To remove this, try running a Spotlight search and delete system preferences plist from User library > Preferences > com.apple.systempreferences.plist
The file path should look like this:
/Users/Username/Library/Preferences/com.apple.systempreferences.plist
You might also want to delete the login plist if you have it
/Users/Username/Library/Preferences/com.apple.loginitems.plist
Alternatively, you can click on Go in your systems toolbar > Go to folder > and type in the path name (keep in mind Username should be replaced with your own). Then, restart your computer. These files will come back as new (without any corruption) and you should be able to completely remove the FigmaAgent service from login items without any issues.
Please note that Figma will automatically reinstall the login item when you upgrade the Figma desktop app. The only existing, temporary solution would be to uninstall the desktop app and use the web browser.
Our team already has this logged as a feature request internally, but to be transparent, there are no immediate plans on the roadmap to implement.
Nov 21, 2023 9:31 PM UTC
This problem has been around for over six months now, but there is still no fix. This reminds me of Adobe’s behavior. They also did the same thing with the Adobe creative cloud, which bypassed the user and worked in the background on the system. Also, to say that this is only for updating fonts is ridiculous, then open the code for audit so that users can be sure of this.
Nov 28, 2023 4:42 PM UTC
Same issue here, please fix it!
Madis_Liias
Dec 18, 2023 1:48 PM UTC
+1, makes me want to uninstall Figma desktop app
Jan 8, 2024 8:26 AM UTC
Duncan_Babbage
Jan 11, 2024 8:34 PM UTC
As a developer, I would never even consider doing this to my users. It is toxic application behaviour to be installing anything in the Login Items or elsewhere other than during an installer process triggered by a user, and it is thermonuclear to re-install that item once a user has explicitly removed it again.
Even if Figma incorrectly thought that their perceived need to have this item installed trumped user choice, at the very least it would be the most trivial step for Figma to record when it had installed this item once and not do it again if the user removes it.
More to the point, Figma could easily offer me the opportunity via a dialog to install this agent, and let me as a user decide if I want to. For the record, I have absolutely no interest in making my locally installed fonts available to your website so you can stop that right now. Secondly, if you can’t access my locally installed fonts within your native application you need to seriously review your tech stack decisions.
My company chose Figma so I will continue to use it but if I was ever asked my opinion on whether we should change to (insert the name of any competitor including any I had never heard of) I would immediately discuss how user hostile Figma’s approach is.
Devin_Columbus
Jan 12, 2024 6:31 PM UTC
This is the most presumptuous development decision I have seen in I don’t know how many years. Figma is literally the only application that does this, our of dozens and dozens that I have installed and many I use on a constant basis. Personally, I don’t find it “unsafe” but I do find it extremely annoying. This should be removed.
Jan 15, 2024 2:09 PM UTC
There is another way to avoid that, but it involves a few steps and is rather hacky:
1. Move Figma to a disk image
  • You have to create an empty disk image (e.g. .sparseimage) with Disk Utility
  • Move the Figma.app from applications into that disk image
  • delete the old Figma.app in the applications folder
2. Locate the Figma Agent
  • After opening the disk image, right click on Figma.app to “Show Package Contents”
  • Look for the FigmaAgent.app in the Library folder
3. Create an Alias
  • Right Click on the FigmaAgent.app to “Make Alias”
4. Replace the Figma Agent on your System with the Alias
  • Navigate to ~/Library/Application Support/Figma, or right click on the Login Item “FigmaAgent” in your System Settings to “Show in Finder”
  • Rename or delete the existing FigmaAgent.app in that folder
  • Move the alias you created in step 3 to this folder, and rename it to FigmaAgent.app
What this will do
On startup, the login item will try to launch FigmaAgent.app. But as this item now points to a non-mounted disk image, it will not work anymore. So FigmaAgent will no longer launch on startup.
Figma cannot replace the alias, it will not be removed with an update.
Downsides
  • FigmaAgent can no longer be updated
  • You have to mount/open the sparseimage each time you want to launch Figma
Matt_W
Jan 15, 2024 4:31 PM UTC
Trust is a big deal when it comes to security and application deployment. This behaviour violates that trust and means desktop installations for a very expensive product are not possible and can even put contracts at risk. There are plenty of other free design tools, and access to training via YouTube nullifies your argument.
Marjory
Jan 19, 2024 1:30 AM UTC
To the Figma owners, please consider and remove this annoying prompt, as you can already see how many users are annoyed by this prompt. I am sure there is a way around it without constantly reminding users. I think once is fine but not constantly or allow users to have the option to disable this.
Quite logical, right?
Jan 22, 2024 3:04 PM UTC
Add me to the list of frustrated users, this setting is something I’d expect from some dodgy software, not the leading app in the industry
