David_Hernandez
Apr 10, 2025 11:18 AM UTC
"Sort by" does not retain the selection.
Every time I exit Figma and come back, the previously selected sort order is lost, and it defaults to "Last modified" – "Newest first". Previously, the selected sorting option was always preserved.
ksn
ksnSolution
Apr 25, 2025 6:08 PM UTC
Hey both. Wanted to let you know that this was an intentional change on our end. From what I understand, the only page that doesn't reset preferences is the "Last projects" page now.
For more context: this was implemented after feedback from users who thought their files were missing due to filters or sort orders being enabled.
I know this was probably not the answer you wanted to hear, and I completely get why this would be a negative change to your existing workflow. I’m making sure that your opinions and feedback on this are also highlighted as well. We do take into consideration every use case, and want to be sure that changes we make benefit everyone who uses Figma.
Apologies that I can’t offer an alternative solution at this time.
If I misunderstood what your issues were, let me know. I’ll keep this open for now to get any other feedback on this you may have,
Jackie Bang
Dec 18, 2025 8:42 AM UTC
The issue is back!!! 😭
Mert35
Dec 20, 2025 11:35 PM UTC
This issue is so annoying! It should be a very very simple fix why it is not fixed yet?
Mert35
Dec 20, 2025 11:38 PM UTC
When I open my Figma project files, they are always sorted by “Last modified” by default. I can manually change the sorting to Alphabetical order using the dropdown in the top-right corner, but after refreshing the page or reopening Figma, the sorting resets back to Last modified.
I’ve seen other people posting the same issue. I want to push this topic forward with sharing it again. Is it possible to fix it please dear Figma? :)
Luis Leiva
Jan 5, 2026 12:11 PM UTC
@Figma, it would be great if you let users permanently select the file sorting order. Please either remember the last selected option or let users set a default in the settings.
Luis Leiva
Jan 5, 2026 12:13 PM UTC
Hi,
Same issue here, @figma can you please fix it! thanks
Luongnd
Jan 7, 2026 6:59 AM UTC
Having the same issue, our team finds it very hard to find the files we need because we are managing the files in an alphabetically order and it resets back to “last modified” everytime.
Jeff_Allison
Jan 7, 2026 5:29 PM UTC
It is painfully stupid that one can’t change the default view. This is such a time waster.
ReginaMc
Jan 9, 2026 1:31 PM UTC
Came here looking for this problem, adding my voice to the chorus of “please fix this.”
Jan 9, 2026 8:41 PM UTC
Hi all! I'm a PM at Figma. Thanks for the feedback - we recently made an update so sorting resets to the default, which reflects the original behavior for this experience.
We recognize that Figma supports many different workflows, and this change won’t fit every use case. We’re taking this feedback into account as we continue improving the file browser.
nwolfe
Jan 13, 2026 8:45 PM UTC
+1 for this. Default sorting to last modified is not helpful. This setting needs to be maintained throughtout the application. I want to see my folders and files in the same order every time, not wonder where they are because the sorting changed.
