Myles
August 8, 2022
“Link to selected frame” should be restored to the share dialog
Has the functionality for sharing links to selected frame been removed?
I upgraded to Figma Desktop App version 116.2.4, and now I no longer see the option in the dialog that appears when I select a frame and hit the ‘Share’ button.
I double checked, by creating a new document with a couple of empty frames in, and still no luck.
Does anybody else suffer this issue? If it’s been removed, then it’s a massively frusrating regression – we frequently link to individual frames when working with developers and referencing design features.
Myles
MylesAuthor
August 8, 2022
Here’s what I now see –
I can still achieve the same by right clicking and navigating to this option – but it’s a painful workflow with no shortcut as far as I can see.
tank666
August 8, 2022
No, the feature has not been removed. You can still use the “Link to selected frame” checkbox in the Share modal or use a shortcut.
Figma Learn - Help Center
_katha
Same here. This option no longer appears in my dialogue either.
In addition, I also no longer see the usual Share modal. Both in Figma’s Desktop App and in the browser, only a fixed dialogue opens below the Share button (on right-hand side in the toolbar) without the option / the checkbox to link to a specific frame.
tank666
August 10, 2022
If you have selected a frame, clicking on the “Copy link” button (or the context menu item of the same name) will copy the link to the frame. You should see a notification at the bottom of the screen.
Myles
MylesAuthor
August 11, 2022
The option no longer appears in the dialog:
Even when a frame is selected, the ‘Copy Link’ button from that dialog links only to the page, not the selected frame.
As you said, the option is still available in a context menu – but my frustration is more around the option’s removal from the share dialog. Getting to the ‘Copy Link’ option is a bit of a fiddly pain there.
tank666
August 11, 2022
Still, recently the interface of the Share modal has been updated, where the checkbox has disappeared, but the functionality of copying a link to a page or frame remains and works as expected.
I’m sorry, but I can’t confirm this. Watch the video below.
Use a shortcut.
Bill_Stewart
The Figma Desktop App has a shortcut Cmd/Ctrl + L to copy a link to a page or frame.
This is incorrect. When a frame is selected, Cmd/Ctrl + L puts a link to the entire page on the clipboard, not a link to the frame.
Linking directly to a frame is actually extremely important on a daily basis. It should not have been hidden away or made harder to do.
  1. “Link to selected frame” should be restored to the share dialog.
  2. The hotkey would also be great (if it worked). It should link to a frame if selected, or the page if nothing is selected.
tank666
August 11, 2022
Again, I cannot confirm, because on my side the shortcut works as expected, that is, if a frame is selected, then a link to this frame is copied to the clipboard.
Please post your request in the Share an idea category so that anyone can vote for this idea.
Calvin_Kuo
Maybe there are actually different versions?
I am using Enterprise from my work, desktop app on a mac.
My Share modal also was updated… including more tabs on top like Myles (Invite, Settings, Embed, Publish to Community), but similarily missing link to frame.
Compare to Tank666’s screenshot, which still shows the old modal (and only the original 2 tabs).
Jim_Jordan
August 23, 2022
I am experiencing the same issue on Figma enterprise. This is a massive problem as my team links to individual frames in Jira.
