Mr.Biscuit
Jan 23, 2021 3:44 AM UTC
LAUNCHED: True Aspect Ratio Lock
Can we get a true aspect ratio lock when the ‘Constrain Proportions’ is on?WX20210123-114719@2x A true aspect ratio lock means two things:
  1. When dragging on a node with ‘constrain proportions’, its width and height always stay in their original ratio no matter which direction you drag it.
  2. When resizing on the parent of a node with ‘constrain proportions’ that happens to be constrainedWX20210123-112532@2x, the node takes on the smallest of its supposed width and height, and calculates its ratio accordingly.
This would be so very helpful to polygon shapes that want to stay in that shape. Consider a spider chart. When you resize its parent, you don’t want the ‘spider net’ to squish squash; neither will you want a doughnut to turn into an oval.
*Resizing of the node’s parent layer is inevitable if you need responsive designs.
Pinned Reply By Celine_
Hey everyone, thanks for your patience! It’s fully rolled out now!
You can now lock the aspect ratio of almost any object in Figma – including frames, shapes, images, videos, vectors, and text – so that the proportions of that object are respected as you scale the object or its parent container.
 More info in the release notes here.
Ludwig_T
Jul 27, 2023 5:37 PM UTC
I’m trying to make a video player component with some variant for aspect ration and I’m frustrated by the fact that instances don’t have and option to:
  • Edit constraints on instances
  • Chain H and W when instances is set to: Fill, HUG or FIX
Adding any of those would fix the issue but so would including a “Fit” option the the size drop downs.
Ludwig_T
Jul 27, 2023 5:41 PM UTC
While this is true for regular frames and auto layouts it definitly does’t work with component instances as the button does not even appear in the UI for those.
Shengfeng_Gu
Jul 31, 2023 11:06 AM UTC
please implement such a feature!
wgo
Aug 1, 2023 12:01 AM UTC
Yes, please consider this, @Figma. Now with Auto-Layout getting even more useful with each update, why do we still have to use weird components for simply having a dynamically scaling image with a true aspect ratio lock. And the components even provide only a certain number of fixed ratios… I mean, yeah, it works and I like clever engineering, but you could also simplify this whole thing a lot, couldn’t you? 8-)…
Kelsey_Waara
Aug 15, 2023 2:31 PM UTC
Ugh seriously come on Figma!!! I am trying to make a video player component and the video thumbnail needs to stay the same proportion when resized. I cannot for the life of me find a way to do this.
Hoby-Van-Hoose
Aug 25, 2023 8:40 PM UTC
For a while now to support a responsive layout grid, we’ve had to make image components with 1 variant for every width of column spans across the breakpoints we target. Since we’ve settled on 4 ratios for images and videos, this demands A LOT of variants that are the same thing repeated.
If however, we could utilize true fixed ratios with variables and min-max settings—these could be reduced to single components. Actually with enough variables they could even be one component. Situations like hero images could benefit from ratios switching at different container widths.
Also, ratio lock could be especially useful if it could be defined like 2:1 and 16:9 in addition to being arbitrary.
Ian_Palmgren
Sep 13, 2023 5:50 PM UTC
Adding a comment to keep this thread alive. Been asking for this update for… years. This is such a common design paradigm, I’m unclear on why this hasn’t been added yet. Hopefully soon!
Sep 16, 2023 5:38 PM UTC
Please make this happen 🙏 🙏 🙏 I was as surprised as everyone that there is no ability to lock a frame’s aspect ratio once the rollout for min/max attribute was added. I have a navigation component that is used across various brands. The logo image component must be variable with maximum width and height restrictions. A square 1:1 logo image component that’s larger than a frame’s maximum height either exceeds that frames height or is clipped depending on if I switch the frame’s autolayout from Fill to Hug. I can’t do anything to make it scale proportionally except for detaching the navigation component itself, which is not ideal since all brands will the the same navigation component… 😭
Petr_Siroky
Sep 23, 2023 2:16 PM UTC
Agreed completely. Coming from Adobe XD, the way it worked there was a no-brainer. Figma is a great and powerful tool, but quite often, the UX is so poor, with so many bizarre and unintuitive choices that puzzle users greatly, like this case - when I lock proportions, I expect this to work universally, not expecting it to only work for manual number entries - in no way this is a clear expectation.
Frederic_Fornini
Oct 3, 2023 12:43 PM UTC
Beside a tricky workaround called : “Fixed aspect ratio in Figma Auto Layout (Community)”. There’s no actual way to implement a proportional image (auto-layout, artboard) resize while keeping the object aspect ratio.
It would be nice to add on top of “hug”, “fill”, “fixed” a proportional version of fill with constrained aspect ratio.
This would ease design implementation and limit the number of needed components to deliver all the different size variations. I know, it’s been posted already a while back and many times.
It also makes sense on a development point of view, as we use these techniques all the time on actual websites.
