LAUNCHED: State management for prototypes
  • February 26, 2021
  • 205 replies
  • 21045 views
Show first post
Vladimir_Kozlovsky
This is an extremely important and necessary feature that will open up great opportunities for using interactive components!
Pavel_Martynov
+1 I am making flow for creating the object in 3 steps. Without resetting stepper component state I am stuck on last step every time after first testing
Andrei_Iancu
There is an even more annoying problem with the addition of component props: if you change the state of a prop in the instance, then in the prototype you press R it will jump to default variant props, and there is no way to avoid this. 😭
You can fix that by reloading the prototype or by modifying the prop in the editor (which means that you have to share the prototype on a very controlled environment).
Rob_Corradi
I think the ideal fix would be something that allowed us to chose how the components behave with would be best, with a “Reset on exit” or similar option available in the Interaction details panel that would give us the best of both words.
With “Reset on exit” on, the component resets to its default state.
With it off, the component stays how it was left by the interaction.
anastako.design
+1 this is important feature and makes a lot of sense its really a share we cant reload each component
Adam44
  • September 14, 2022
+1. This would enable powerful looping animations containing nested looped components based on ‘after delay’ triggers
Berlinguette_David
This is a big miss. I’d suggest more interaction between variants and outside elements. For example, on button click change component X variant state to… In addition, include an “on frame load” interaction that can also set the variant state. Currently there is the “after delay” interaction that works if you set the delay to 0 or a tiny fraction of a second (if 0 isn’t allowed). But I think the key here is allowing change of variant state from elements outside of the variant. That would make my life much easier.
Pieter2
  • September 27, 2022
+1
I hope there will be an option for resetting animation within interactive components in the near future. But since the lack of reaction from the @Figma_Team I fear the worst. #justdoitalready 😉
Hooman
Still waiting on this update. Anyone know if it’s in the works?
Work arounds I’ve come up with are not very elegant.
Daniela_Todorova
Thanks a lot!! 💜 I was seraching for a way to load an element after delay only once (by first load of the prototype) and that’s what exatcly needed! Copied the first screen and with few changes have it in seconds done!! 💯 Thanks!!
Giuseppe_C
  • October 15, 2022
Adding my +1 to the choir, this feature seems to be pretty fundamental when dealing with interactive components
yoann2
  • October 18, 2022
No news from the team on this one? Really needing this 🙂
filip7
  • October 20, 2022
+1
Fix this please.
Zachary_Foster
Running into the same issue…makes it waaaaay hard to use interactive components when there isn’t a way to ‘refresh’ their state or have a reference marker tied to a frame.
Karl_Kipper
+1, its been a year soon…
Sam_Rousseau
+1 - has anyone figured out a work-around for this? I have a selected state on my components, but only one thing in the prototype can be selected at once. I think I have to override it and do it frame by frame, but that’s a much more complicated prototype.
nikitin
  • November 3, 2022
+1
This bug is a very disappointing 🥲
dennsi
  • Active Member
  • November 4, 2022
+1 Frustrating
Mike_P
  • November 4, 2022
Same problem… Where is the answer? I used to use Proto.io and they just gave you multiple actions upon click… you could navigate to another frame and change the state of the navigation component. Why is this tens of billions of dollars company not able to do something so remedial?
Barry_Lachapelle1
oooof this is a killer - just ran into this. I want a component to go to the default state when I close an overlay. That should be a pretty common use case I would think.
Roland3
  • November 15, 2022
+1 frustrating if you spent some hours on a prototype only to discover such a simple thing is not possible
Jake_Snyder
+1 Would save on some frames.
James_Debono
+1 for this
Sam_Rousseau
Me too - I only use interactive components for hover states.
Tim_Ruiters
Why is this still not possible? It can be a simple checkbox “force state” for the frame you want to force the selected state, so you can also keep track of the state if you want to.
