pinquitte
Feb 5, 2021 10:07 AM UTC
LAUNCHED: Horizontal scroll the layers panel
What do you think about having a horizontal scroll on the layers panel? I can’t see the name of the layers and usually widen the panel to be able to see, but since I use a 13", this makes the canvas smaller.
Matia_Gobbo
Mar 20, 2024 1:24 PM UTC
After reaching out to Figma support recently it appears that this is a bug which is under active investigation. This is what their support team replied:
"After some digging, it appears there’s a related bug that our Engineering team is actively investigating. I went ahead and added your encounter with this issue to our ongoing bug report. While I can’t guarantee an ETA on a fix, I can bubble this up with our engineering team for some more visibility at the very least.
We’re generally not able to hold conversations open through long bug investigations as these can take some time, so you may see this conversation is closed. This conversation status isn’t an indication of the ongoing bug investigation. If you see this happen and have any follow-up questions or want to check on progress, just reply here and the conversation will re-open so we can take a look."
I would suggest to as many of us as possible to directly raise this issue with support, so that they can “bubble it up” to engineering in order to speeding up the investigation process.
Mar 22, 2024 10:16 AM UTC
This is really crazy, why there is max width for side panel. It should be completely on user how huge area wants to have. i cant see layer names even if i have huuuge monitor. Software for UX and cant handle this annoying UX problem
marinah
Mar 22, 2024 7:55 PM UTC
I use the home page left sidebar to organize files and access them quickly (and it’s very helpful for that). However, I think it would be even better with a few feature additions:
  • I treat my sidebar lists as personal folders that improve my efficiency, whereas my team as a whole has its own system of organization for files in projects to ensure that all stakeholders can navigate easily to the right files. I would love to be able to click into a sidebar list and view its contents in full page mode in the same way that you can click into projects and view their contents. Pinning could function in the same way it does in projects, but pinned items could also be displayed as pins at the top of a list in the sidebar. This would allow me to treat a sidebar list as a project without impacting the organization system that others on my team see and use.
  • It would also be very helpful to have the ability to sort (in both the sidebar view and the full view detailed above) sidebar contents by recency so the ones I’m currently opening the most frequently and recently could be bumped up to the top of the list organically without requiring manual reorganization. Obviously, the current behavior should also be retained as a custom order option.
Colin10
Mar 26, 2024 7:20 PM UTC
This is actually becoming a huge issue for me (and other team members) too. I’ve expanded the left side layers panel as much as Figma will allow, but nested layers still don’t have enough space to show up.
Wendy8
Mar 27, 2024 8:20 AM UTC
I find it really discouraging that this feature was requested in 2021 and in 2024 nothing has been done about it. At least the left panel is expandable but the right panel is not and it truncates values and makes using Figma harder. Please make the right panel’s width expandable, too!
David_W
Mar 27, 2024 2:39 PM UTC
Your community support agents have said over 3 years ago that it’s “on the radar”. There are many topics about it created in this forum throughout the years with unanimous agreement that this problem obviously shouldn’t exist. This is clearly a major usability issue affecting thousands of users, which can’t be complicated to fix. Some users are copying some small CSS snippets into the console as a workaround but most are unable to find that workaround. Most companies would have addressed it quickly. Why do you guys continue to ignore this? That years later you’re still “gauging reactions and may consider it in the future” is baffling and insane. @Figma_Moderation
Matty_Vazquez
Apr 9, 2024 12:39 PM UTC
I feel like this is a really, really, stupid oversite. Why is this still a thing? Figma used to be so good at incorporating thoughtful usability into their product. Why are we (the community) having to tell Figma through “votes” that this needs to be fixed? Quit f-ing around and fix this instead of stroking some manager’s ego by shoving variables out the door!! Overflow-x: scroll this thing already!
Michael_Kalus
Apr 9, 2024 2:47 PM UTC
Oh well…
it’s 2024 and Figma releases custom cursors instead of meaningful fixes and features. #priorities
It got on my nerves so much that I started a new attempt to find a solution. As I couldn’t find where the application sets the max-width limit of 500px, I thought well let’s introduce just a button that solves that problem.
Increase Layers Panel Width Tool
CleanShot 2024-04-09 at 14.03.43
The new script adds a button to the left toolbar that sets the whole left sidebar to a width of 1500px. That should give anyone enooooough space (fingers crossed) to work with deeply nested components.
The button can be toggled on and off. The maximized sidebar cannot be adjusted to any width, so we have the following options: default (resize to any width between 225px and 500px) or custom (make it finally wider!!! at 1500px).
Demo
CleanShot 2024-04-09 at 15.05.03
How to install/use
Userscript
Figma App
  1. Open the dev tools in Figma with cmd+opt+i (on macOS)
  2. Switch to “Console” tab.
  3. If you are doing this for the first time, the console may not allow pasting due to security reasons. You get a warning message in the console. Just type “allow pasting” and hit return.
  4. Paste the following code and hit return.
Pro-tip: You don’t want to copy and paste the script for every file over and over again? Within the console you can navigate through your history with the up and down arrow keys. Hit up and return and you are done.
Updated: 18.04.2024
(function () {
    'use strict';
    // set left toolbar
    const toolbar = document.querySelector('[class*="toolbar_view--buttonGroup--"][class*="toolbar_view--leftButtonGroup--"]');
    if (toolbar) {
        // create new button, set inner HTML and append
        const newButton = document.createElement('div');
        newButton.innerHTML = '<span role="button" aria-label="Increase Left Panel Size" class="svg-container toolbar_view--iconButton--1MUm6 toolbar_styles--enabledButton--fEwmC" data-tooltip-type="lookup" data-tooltip="set-tool-increasewidth" tabindex="0" aria-pressed="false" data-fullscreen-intercept="true"><svg class="svg" xmlns="http://www.w3.org/2000/svg" width="20" height="20" viewBox="0 0 20 20"><path fill="#fff" fill-opacity="1" fill-rule="evenodd" stroke="none" d="M18.6.2H1.1c-.3,0-.5.2-.5.5v18.6c0,.3.2.5.5.5h17.5c.3,0,.5-.2.5-.5V.7c0-.3-.2-.5-.5-.5ZM1.6,1.2h11.1v17.6H1.6V1.2ZM18.1,18.7h-4.4V1.2h4.4v17.6Z"></path></svg></span>';
        toolbar.appendChild(newButton);
        // set new resizeButton
        const resizeButton = newButton.querySelector('.toolbar_view--iconButton--1MUm6');
        let isButtonClicked = false;
        // Add click event listener to the span button
        resizeButton.addEventListener('click', function() {
            // Toggle background color, run width adjustments and start mutations observer
            if (!isButtonClicked) {
                resizeButton.style.backgroundColor = 'var(--color-bg-toolbar-selected, var(--bg-toolbar-active))';
                setWidths();
                observeMutations();
            } else {
                // reset background color, reset width adjustment and destroy mutations observer
                resizeButton.style.backgroundColor = '';
                revertWidths();
                disconnectObserver();
            isButtonClicked = !isButtonClicked;
    } else {
        console.error('Target div not found');
    let observer;
    // width adjustments
    function setWidths() {
        document.getElementById('left-panel-container').style.maxWidth = '1500px';
        const elements = document.querySelectorAll('[class*=left_panel_container--panel--]');
            elements.forEach((el) => {
            el.style.width = '1500px';
        const leftPanelContent = document.querySelectorAll('[class^="left_panel--content"]');
        leftPanelContent.forEach(content => {
            content.style.width = '1500px';
        const objectRows = document.querySelectorAll('[class^="object_row--row--"]');
        objectRows.forEach(row => {
            row.style.width = '1500px';
        const objectRowsInstanceChilds = document.querySelectorAll('[class^="object_row--instanceChild"]');
        objectRowsInstanceChilds.forEach(row => {
        const topLevelRows = document.querySelectorAll('[class^="object_row--topLevel--"]');
        topLevelRows.forEach(row => {
        const scrollContainers = document.querySelectorAll('[class^="objects_panel--scrollContainer"], [class^="pages_panel--scrollContainer"]');
        scrollContainers.forEach(container => {
            container.style.width = '1500px';
    function observeMutations() {
        // Observe changes in the DOM subtree of the left sidebar and run width adjustments
        observer = new MutationObserver(mutations => {
            mutations.forEach(mutation => {
                if (mutation.type === 'childList') {
                    setWidths();
        const config = { attributes: true, childList: true, subtree: true};
        const motionContainers = document.querySelectorAll('#react-page');
        motionContainers.forEach(container => {
            observer.observe(container, config);
    // function to revert width adjustment
    function revertWidths() {
        document.getElementById('left-panel-container').style.maxWidth = '500px';
            el.style.width = '500px';
            content.style.width = '500px';
            row.style.width = '500px';
            container.style.width = '500px';
    function disconnectObserver() {
        if (observer) {
            observer.disconnect();
Hacking a productivity application to be productive… Great success!
If you find any bugs, let me know!
aolko
Apr 9, 2024 4:14 PM UTC
can you make it resizable and add a horizontal scroll?
Paul_Van_Tuyl
Apr 11, 2024 4:27 PM UTC
Please fix this, even on large screens with the limit to the width of the layers panel it makes it challenging to work on components from libraries etc.
