LuisPaico
Feb 9, 2021 9:19 PM UTC
LAUNCHED: Allow modifying "Decoration" to the text styles already defined
One option that could be useful is to allow modifying the decoration of a text that has already been defined as a text style, because that way you do not have to create two or more text styles to simply add the decoration. As with alignment, it could be added below. thanks
Captura de pantalla 2021-02-11 a las 18.43.18
Will_C
Jan 3, 2023 10:45 PM UTC
Would be great if someone from Figma could respond to this thread.
Fernando9
Jan 11, 2023 6:40 PM UTC
+1 Please do it already =)
Cheryl_Lemoine
Jan 16, 2023 10:12 PM UTC
Holy geez, this has got to be implemented!! Figma, are you listening to this thread?? Running into this exact issue building our design system. I echo the comments that it’s ridiculous to have to either build in underlines in another font style OR break the link to apply them… /mutters to herself “I can’t believe this is a thing…”
Diana_Pop
Jan 17, 2023 7:17 PM UTC
+1 this - it would help sooooo much to have this!
Bauke_Schildt
Jan 25, 2023 10:21 AM UTC
If this is still something you need, instead of doing this manually, you should use the subscript unicode character for that. Most (but not all) fonts support this.
Char Description
₀ subscript 0
₁ subscript 1
₂ subscript 2
₃ subscript 3
CO₂
Same for superscript:
Char Description
⁰ superscript 0
¹ superscript 1
² superscript 2
³ superscript 3
⁴ superscript 4
herkulano
Feb 5, 2023 11:30 AM UTC
Yes, yes and yes!
James_Mckernan
Feb 6, 2023 4:45 PM UTC
+1 Needs to be fixed!
dennsi
Feb 15, 2023 8:41 AM UTC
Also this:
Once a text style is applied all type settings that are inseperable from the style are hidden in the menu (left screenshot). Case still appears in the menu list but it should be hidden as aswell since it breaks the style and cannot be changed independently.
Feel free to vote here:
Ryan_Hudson-Peralta
Mar 1, 2023 4:40 PM UTC
This works until the text wraps
Tomas_Kvasnicka
Mar 24, 2023 7:56 AM UTC
Usually, this is the problem for body text styles (paragraphs) where you often need to add not only strikethrough and underline but also bold, for example.
The system solution would be to introduce text style variants or parameters, just like components have it. For example, the design system creator might decide that an H1 headline would allow only one possible variant (because you don’t want your designers to change it), whereas the Body text would offer more variants (e.g., regular, bold, underline, strikethrough).
Right now, we have 5 different sizes for Body text in our design system (Body 1 to Body 5). Each of them has separate styles for regular and bold weights, i.e., 10 different styles (not to mention mobile versions). When we need strikethrough or underline text, we have to detach the style because that is less painful than having 40 different text styles. It is still very painful, though.
