Remi_Fayolle
Mar 8, 2021 11:18 AM UTC
Interaction between components
Hello
I would love that one component interaction can impact another component
Example : i’m working for a video communication tool. I would like that when i mute microphone, it changes variant of the stream to indicate that microphone is muted
I have two components : Stream and ToggleMicrophone. If i have microphone in state muted i would like that stream has muted indicator state
Andrey_Denisov
Mar 24, 2023 6:55 PM UTC
It would be very helpful if Figma release such feature 🙏
Todd_Vachon
Mar 30, 2023 3:04 PM UTC
Agreed. I’m running into the same issue mentioned previously where I need a combobox menu selection to add or remove fields from a form. Being able to change the state of another component would really help simulate more complex interactions like that.
May 25, 2023 1:30 AM UTC
Here I was hoping this type of interaction was possible without making a whole new page. I’m new to Figma, but adding my voice here to say this feature would be a huge time saver.
Makroon
Jun 15, 2023 9:20 AM UTC
Voting this feature up as it is a ginormous must-have! Let’s get it in the air ASAP Figma! 🤓
It can be replicated by adding more frames/canvas, but darn… that is such a workaround!
fernandolins_cs
Jun 15, 2023 1:08 PM UTC
+1 for this, sometimes we need to protype interactions in which multiple parts of the UI have to be coordinated and it doesn’t make sense to have everything as a component variant
tank666
Jul 25, 2023 10:43 AM UTC
This became possible from June 21, 2023. I also answered you here: Change variant of a component from a different component - #2 by tank666.
Figma
Aug 8, 2023 11:31 AM UTC
The container components is great in some situation, however, when the first component set control a video play, that triggered by a play icon, and the video rectangle also hold a role of these variants. The other component set is the animation of timeline, which process after the play icon is clicked. I have no idea when they are in different components,
Amberto_Brasil
Aug 13, 2023 11:24 AM UTC
Fortunately we have variables now, and the patter I suggested is no longer needed.
Johan_Jenefeldt
Sep 1, 2023 12:35 PM UTC
That you actually can do right now.
You can create a boolean variable (true/false) and connect that buttons visability to that variable. Then you add a click event to the checkboxes that change the value of that same variable.
Sep 2, 2023 1:47 AM UTC
True, there are tons of prototype things that Figma can learn from Axure, Our team has been using Axure for a long time, and we recently want to change to Figma, so our docs, prototypes, and UI can be All-in-one. but sadly, Figma can’t prototype a lot of things! One of the very important reasons is it can’t interact between components!!!
