megaroeny
Aug 19, 2021 7:37 PM UTC
Finding Missing Library components/styles
First off, I’m loving the new Swap Library feature!
Problem
Today, it actually helped me discover some “rogue” styles and components that were leftover from an old library! Now I can try to locate those and finally get rid of them in our current library!
But wait - what if I don’t actually know where these are in the file? Or even further, what if I can’t get Figma to find a match?
Suggestions:
  1. The one thing I wish this feature could do is to help me actually locate those rogue styles or components. I tried using the Instance Finder plugin but it still didn’t help because I have to actually locate them on the canvas/file first. ☹
  2. What if the dialog let us force a new style or component match, instead of us running into a dead-end with the None found message. Currently, it tries to match using the name. But that might not always work (like in this case.)
Any ideas are appreciated. Otherwise, wanted to pass this suggestion on to the Figma team. Thanks!
Marie-Eve_Vesel1
Jun 8, 2022 2:32 AM UTC
The same idea can be used to look for missing components:
  1. Create a new component with the same name as the missing one: make it big with a background color that clashes with your brand colors (for instance, bright pink) and include text that says ‘MISSING COMPONENT’.
  2. After swapping the component, add a little ⛔ icon in the name (or something similar to indicate there’s an issue with that component).
  3. Now you can easily identify the missing component instances either in the layers panel or directly on the canvas when you see that bright pink rectangle disrupting your beautiful designs. At that point, you can replace the dummy instance with what’s actually supposed to go there.
  4. Delete the dummy component (bright pink is overrated after all).
It’s definitely a brute force, manual process, but it works when all else fails.
Monique2
Jul 1, 2022 4:53 AM UTC
That’s so smart. It worked for me.
Tsurit_Ben-Tsur1
Jul 16, 2022 12:34 PM UTC
Hey 🙂 I’m Tsurit (She) the developer of this plugin. Thank you for this awesome feedback, I’m glad it helps you!
Alexandre_Istrasoft
Jul 18, 2022 1:37 PM UTC
you’re welcome ! thanks to you for the plugin !!
Jessica_Coser
Jul 20, 2022 1:14 PM UTC
I haven’t find a way to fix this issue with components, but with styles you can delete each style and that style group title will be removed.
it still be present as “missing library” however it will not bother when searching for a style
Jason_Post
Jul 28, 2022 6:28 PM UTC
edit - added reply to original poster of code Pete_Lada under this post
Hi @Sam_Walsh wanna check if your console syntax still works on your end. Found your post, and tried it on Figma Desktop App version 116.2.4 but I can’t get anything to select.
Attached screenshot of fresh file with Header1 text style I tried to run the console log search with.
Jason_Post
Jul 28, 2022 6:30 PM UTC
cc tag @Pete_Lada if your console syntax still works on your end for finding missing text styles. Sorry I missed you in first reply post, see above for details and screenshot. Thanks in advance!
Pete_Lada
Jul 28, 2022 6:56 PM UTC
make sure you’re searching for the correct thing. looks like you’re searching for an effect style name in your code, where you probably want a text style (textStyleId)
Jason_Post
Jul 28, 2022 8:35 PM UTC
Yup, that’s what I missing, thanks @Pete_Lada !
For reference, changed var style = figma.getStyleById(n.effectStyleId); to var style = figma.getStyleById(n.textStyleId);
And variable ID names seem to be:
  • textStyleId for Text
  • effectStyleId for Effects
  • fillStyleId for Color
Thanks so much everyone! Community is giving me ways to hack around Figma’s shortcomings!
Jesse_S
Aug 4, 2022 9:02 AM UTC
Would it be possible to also use this line of code to swap styles with a library style?
What would that code look like? Because I’m not a coder at all 😅 But that would be very helpful for my use case
