eokic-hexis
May 5, 2021 12:22 AM UTC
Figma prototype UI obscuring fixed website header
    Screenshot and sample file below. I’m using an iMac sized frame with extended height. This issue is exacerbated by the fact that this is the now the default view when using multiple flow starting points and is the only way to actually change the flow starting point. So you have a constant trade-off of whether you want to see the Figma controls or your prototype’s. Annoying as hell.
EDIT: When sidebar is hidden, the fixed header is visible but inaccessible. As soon as the cursor hovers near it, the Figma UI appears over the (clickable) website header. Wow…
  1. Add as much context as possible (screenshots, Figma files, mockups, etc.)
    https://www.figma.com/file/WlYbWyHwtBGEFZihdMt2az/Bug-Obscured-fixed-header?node-id=0%3A1
Harding_Kerry
Oct 6, 2022 9:40 AM UTC
+1 please fix this
Steve_James
Oct 7, 2022 11:05 PM UTC
Fix this please Microsoft! Oh wait.
Charlie_Pratt
Oct 10, 2022 2:16 PM UTC
Honestly, I can’t think of a single reason why the top bar needs to overlay the deisgn at all. It’s really painful.
Ryan_Brown1
Oct 18, 2022 1:43 AM UTC
What if there were several view settings for the bar:
  1. where its completely hidden and activated by the key command,
  2. where it collapses down to a icon that floats, fixed, above the design in the lower corner of the page,
  3. where it’s the full bar, but the bar is no longer overlapping the design and simply above the design
Dylan2
Oct 31, 2022 3:03 PM UTC
Wait, this has been open since July 2021 with no resolution? Our clients should not have to show/hide the ui in order to navigate around and/or comment.
Markus_de_Ligt
Nov 11, 2022 11:40 AM UTC
Setting the prototype device size to custom 1920/1080 (as is my design) solves me a lot of troubles. The Figma UI still there but prototype fully visible. Then the CDM+ \ trick to hide the Figma UI and copying the link shown as ‘Copy sharing link’ at the bottom finally returns a link to a clean prototype with only a black border around.
Joost_developer_view
Nov 15, 2022 12:20 PM UTC
This is so frustrating, why isn’t there a fix yet?
Scott_Clark1
Nov 16, 2022 3:55 PM UTC
Why is this still an issue? Over a year and 73 complaints later for such an obvious problem. Please fix this!
Laura_Rodriguez1
Nov 18, 2022 5:24 PM UTC
As a hack, I ended up just adding a black rectangle at the very top of my frame (that matches the prototype background) to push the header down into view.
Stephanie12
Nov 18, 2022 9:06 PM UTC
I used that hack too until my dev coded the top rectangle into the design -_-
Pleaseeeee fix Figma!!
