xlc
Jul 19, 2023 9:36 PM UTC
Enable selecting subfolders when selecting preferred values for an instance swap property
When I create an instance swap property I have the ability to add preferred values. However I’ve arranged my components (icons) into multiple subfolders. And to my dismay, selecting the top-level folder does not automatically also select subfolders. So now I have to click into each subfolder in order to select its contents. It feels like I’m being punished for being organized.
Request:
  • Please enable the selection of subfolders from the parent folder level (without having to click into it first).
  • Please make the default behavior such that selecting a parent folder also selects all the subfolders and all the contents within it and any other nested subsubfolders and their contents, etc.
Oct 17, 2023 9:36 PM UTC
Armin_Rouhanian
Dec 19, 2023 2:50 PM UTC
Continuing the discussion from this link:
While we create a component (like a simple button with an icon) with an instance property, we need to select many components for preferred values all at once. It would be good to have an option to select all components inside one of the items in the following list:
  • Group
  • Section
  • Page
  • Different file
  • Library/part of library
I’m looking forward to get any comments, suggestions, or alternative solutions for this 😃
Armin The Riverman
r_sh
May 28, 2025 4:32 PM UTC
+1. We are working on a base icon library where all the icons are organized in a very general way.
As an example:
General: icon/general/star, icon/general/heart
Notification: icon/notification/badge, icon/notification/alert
System: icon/system/settings, icon/system/calendar
We would like to be able to make a secondary organization of the icons for a specific product, and access that using Preferred Instances.
As part of this, we are making sets of icon Instances in Sections. In this case, I might need a set of icons called “Control Menu” which uses the star, heart, badge, alert, settings gear, and calendar. This “Control Menu” is like a sticker sheet so that designers and developers have a clear visual reference to the icons allowed to go here. Any button or other component that needs access to the “Control Menu” icons set will use Preferred Instances.
We would like to be able to make an Instance Swap property for a component and to have the option to select Preferred Instance values from that “Control Menu” Section-- instead of going to the Preferred Instance settings and manually selecting each relevant icon from “General”, “Notification”, and “System” every time that we make a component which uses the Control Menu icon options.
This is easier to do if we make a Component Set with Variants, and each Variant is an Instance from the icon library, but Variants do not offer the same type of granular control and flexibility that Instance Swaps with Preferred Instance values do. Instance Swapping allows our overrides such as color and size to preserve.
xMOx
Apr 30, 2026 8:16 PM UTC
I’m running into an issue where I need to have the option to select a Specific folder of components for instance swap.
Here is the scenario, I have 2 Icon packages one is Lucide Icons and the Other is our Custom Icon set. Since each icon package has different properties I wanted to have a “IconPlaceholder” that has a property in it called “Icon Package” that u click on it and it will give u a Dropdown that has 2 options “Lucide Icons” and “Custom Icon Set” to select from. So if I select the “Custom Icon Set” and then go to the the next property which is the Icon Swap dropdown the issue here is that I can search the entire library and would pick the a Lucide icon which doesn’t fit the property I set above
Solution, I need to have the ability to select a specific folder for the instance Swap so that when user decides to want to search it will only search that folder and not the entire library that has other components that are not relate. I hope this makes sense, I did a small image below to illustrate what we could do.
