Oscar
Feb 10, 2021 5:26 PM UTC
Create component inside another component
Say I have a component of a card and after various iterations in my design I want a group inside that card component to be a component but the “Create Component” option won’t show up.
So every time I stumble upon this problem I have to take that group out of the card component, then create a component out of that group and then place it back inside my card component.
Is there a reasoning behind not allowing users to create components within components?
kolyba
Feb 10, 2021 5:59 PM UTC
That’s how Figma works, main instance of the component cannot be inside of another component
Oscar
OscarAuthor
Feb 10, 2021 6:35 PM UTC
Yep, I clearly understand that’s how Figma works. I’d like to know the reasoning behind that, though.
A solution would be: If you try to create a component within a component, the created component appears as an instance and the main one appears outside the component you’re working on.
kolyba
Feb 10, 2021 7:17 PM UTC
That’s exactly the way it worked not long ago. Maybe some folks from Figma can elaborate on this change
Josh
Former Community Manager
Feb 11, 2021 7:39 PM UTC
No change here. It works the other way around… so if you have a main component within another layer and make that parent layer a component, then it will move the component outside and place an instance within it.
Alexander_Vinogradov
Mar 12, 2021 11:13 PM UTC
+1000!
It’s a very common use case. First, you iterate and brainstorm, then you organize. First, you create a widget, and later when you a happy with it - you decide to break it into several sub-components (generalization process) While the widget is already a component - breaking it up into several components becomes a very tedious manual process. Here is an example:
  1. Crete play card component. It has 3 params(Health, Mana, Element), text, image and background.
  2. When you happy with a card design you decide to make each of its properties components since they will be used elsewhere. So you want to convert Health, Mana, Element, and Background into components.
  3. You select each of those elements and copy/paste them outside the Card master component.
  4. You convert each element into a new master component.
  5. You replace existing elements inside the Card master component with instances of HP, Mana, Element, and BG components (trying to match position and scale)
  6. Then you decide that BG should have 2 subcomponents as well! Frame and actual BG so you repeat the same tedious steps again and again.
The solution would be:
when the user tries to convert any element inside any master component(MC) into a new component - just create the new MC automatically in the first parent node which will allow that and place it near the edited area. If there is some issue with the team library and shared masters - place the newly created MC in the same scope/document/library as a currently edited MC.
Wolfgang_H
Apr 18, 2021 5:44 PM UTC
I agree that this is a dumb extra step they make us do. This should be converted to a product request, if it’s not already.
Thomas_dF
May 4, 2022 6:13 AM UTC
Would love to be able to split components into several when needed too
Jairo
May 4, 2022 6:47 AM UTC
Oh i think i have two workarounds for this!
First is a plugin: Pop a component: https://www.figma.com/community/plugin/940714430683584876/Pop-a-Component
You press the thing and it makes a component out of the object you have selected, leaving an instance in its place.
I also macroed with Autohotkey so i have a button on my keyboard that creates a regular component, but when i double press it it runs the plugin.
The other solution is more manual and i use it when there is a “delicate” layout and don’t want to trust automations:
I just copy the element i want to be a component and paste it outside the parent main component. Then i create a component out of it.
Last i copy the component (to be able to paste it as an instance), then i select the original group/frame i had in the parent main component, and substitute the whole thing with an instance by pressin ctrl+alt+shift+v
Power Member
Jun 8, 2024 3:41 PM UTC
Just found this topic and wanna share a possible solution using my plugin Master.
Check out this short video showing it in action. I created a single component from 3 objects inside of the main component:
As you can see, compared to other solutions, Master would go through the whole file and find instances of the component that you are changing the contents of, and preserve all overrides in those instances. Master plugin for Figma used to create component inside another component
Additionally, it can create a component from multiple objects at once, or swap them to an existing component, e.g. if you want to replace regular frames with instances or swap instances inside of a main component and keep overrides for instances of that component, you can use Master’s pick and link feature.
→ Try it out
