Choose image or frame as prototype background
Kass
Hello to the Figma team and forum users! I have been learning this tool over the last couple of weeks and I’m amazed at so many of the features and ideas. However, there is one thing I’m struggling to achieve due to a limitation.
When prototyping for some platforms, it’s nice to create a mockup for the overall platform UI (like a Mac/Windows desktop, with a window open), to then use a background for all other frames, which are in turn the contents of that window.
Currently, in prototype viewer mode, it’s not possible to keep this mockup frame as a background for all frames.
One way to solve it is copy-pasting it (most likely as a component) into each and every frame you want to show in the prototype, and placing it behind everything else. That’s a lot of repeated manual labor. Plus, the frames themselves end up bigger - they have to stay at the fixed size of the mockup screen. So checking how your UI’s resize is harderd.
Apart from that, having that background always be visible or clickable is quite distracting, so you need to always lock it or hide it when working, and then unhide before presenting. Again, repetetive manual labor.
Another option is to make the “desktop mockup” frame the starting frame, and only use “show overlay” for any frames that need to show up inside the mockup, but I assume it’s not the best performance-wise, as you end up stacking frame over frame over frame, without ever closing them. Plus that adds limitations that come with the overlay transition mode (no smart animate etc).
The third option is the “device” dropdown, which makes an image of the device screen visible around your prototype, but that’s extremely limited, as it doesn’t let you customize the visual elements/size/devices available in any way.
Instead of all that, it would be very nice to be able to select an image, or even better a frame, as the “background” option in the Prototype tab. This way, you can focus on making individual screens with no distractions and external elements, but preview them with whatever custom background you want.
That way it can support custom size, custom device hardward and device-specific UI renderings, which can be quickly switched by just selecting another frame, or just removed by selecting a one-color fill (the only option available now for “Custom size” device).
I’d love to see this as an option. If anyone has any feedback about this idea, I’d love to know. Thanks!
Ti_n_Nguy_n_Dinh
Pump, I also think this feature would be cool or at least let you change the BG color
Kartik_Iyer
Adding this feature would be really helpful to present prototypes in more realistic setting, showcasing a web application running within the browser, for example. Allowing designers to replicate such realistic scenarios would aid them to better test their prototypes with users by closely mimicking real-world environments.
pixelfUX
  • April 26, 2022
Yes, this would be super useful! Especially, when prototyping stuff for embedded interfaces, where it’s important to keep in mind what’s around the display.
Freeman_Lauren
Bumping this! This would be very useful, also for branding purposes.
It would be very nice to be able to add a background Image to a prototype to simulate augmented reality for exemple
Shamil_Mk
very much needed
Madelynn_Martin
Still need this tool!!!
PatJW
  • 4 replies
  • December 10, 2024
Bump to add a +1 to this idea. We’re a hardware company, and it would be amazing if we had the ability to add our own hardware devices in our mockup options.
kms210
  • March 14, 2025
Bump on this as well. Would like to be able to add a background image in the prototype view for physical context and our own hardware devices!
