Phil_Larsen
April 18, 2024
Can't use variables to create a percentage on Letter Spacing
I use percentages in a project for the letter spacing. I can’t use variables to achieve this value. It always defaults to pixels.
Thank you for providing feedback! I will share this with our internal team. Your input is highly valued, and we will take it into consideration for future enhancements.
Stan5
What unit is currently used? I tried converting the percentage to REM but the text shifts when I assign the variable, so REM clearly isn’t the right unit.
Phil_Larsen
April 19, 2024
It defaults to pixels on Letter-Spacing. I tried using a decimal but then it was just a decimal of a pixel.
This issue is also present on line height.
pinquitte
May 10, 2024
This is weird 😦 I cannot use line-height variables for our “label” text style because of this issue. I need to add 10% as a value, but % character is not permitted.
May 17, 2024
Actually, this problem exists since 2021… Any news about it? Thank you very much.
Jeremy_Knudsen
July 23, 2024
I just ran into this problem. What good is having a variable scoped to line-height if it ONLY supports a px value ??
Ed_Kolan
August 1, 2024
Same issue. Cant setup negative 2% or value 😦
kiprou
If pixel values are considered “number variables” then percentage values should be considered number variables too. Please get this fixed.
Emanuel-Mardsjo
November 14, 2024
I’d just like to add to this as well. Would make it a lot easier to set up consistent styles.
Shiv
Just wanted to chime in here and say that this is absolutely required for us as well. Not being able to use tokens for letter-spacing is a gap in our design system that we want to address as soon as possible.
​@y_toku are you able to confirm if this feature is being worked on?
