Viacheslav_Poliakov1
Jun 26, 2023 12:38 PM UTC
Assign variables to variant properties of the main components & nested instances
I haven’t found this in “coming soon” for variables…
As it works now, a variable can control properties only of the topmost component instance. You have to assign a variable again and again to each instance each time you place it, you can not nest components with variables at all.
nomi_sum
Jul 3, 2023 7:41 AM UTC
It weirds me out I can only either have a nice component system or working variables.
As good as this update was I hope it will get expanded soon.
Chris_Beltran
Jul 8, 2023 9:36 PM UTC
Do you have a link to a file where I can see how this works because what I’ve been resorting to is either breaking the component or applying it to a top level instance.
elv-heath
Jul 10, 2023 6:59 PM UTC
Binding to nested components could also help with variant changes across multiple components in a layout. If there are components with size variations and use the same naming scheme, they could all be switch by the mode instead of updating the properties of each one.
Arash_Masihpour
Jul 11, 2023 9:58 AM UTC
Just the way we needed to have control over nested properties to change them instead of creating more variants of parent component, I need to apply variables to the component instances which are in lower levels of another Component (or at least for the nested properties of that top-level parent)
For example, I have an “Item Card” component. I have a different design system which changes a discount tag to another variant of its own.
  1. It is obvious that I can not create a variant for Item Car, only to change a discount tag.
  2. It is not related to prototype to do it with “set variable”
  3. because of transparency of discount tag, I can not do it with a boolean
Danny1
Jul 13, 2023 11:09 AM UTC
Hey,
I would definitely be happy if variables could also be added to nested components and properties, e.g. icons in a button. Also being able to connect “content” of a text property of a component to a variable would be great.
Please the first one would be great as it doesn’t make sense otherwise with nested components.
Jul 19, 2023 11:38 AM UTC
I hope the nested feature is on the way sometime in future, otherwise the functionality wont be compatible with design systems when used in prototyping, likely meaning most will avoid it (or detach everything). Variables are a great start though and the way it’s been implemented is very intuitive, I can’t see why nesting wouldn’t be coming 🤞
Agathe_Mametz
Aug 16, 2023 1:34 PM UTC
The fact that nested variants can’t be bind to variables makes the 2 systems not working together as they should. Can’t wait a release where it’s possible to do that!
CSEng
Aug 28, 2023 5:03 PM UTC
When utilizing Figma’s variables feature, we also have encountered a bug that affects the functionality of our design library. This issue arises when properties and variables conflict, leading to text editing becoming disabled. Here are the steps to reproduce the problem:
  1. Create Component A, which includes a nested Component B containing a text layer.
  2. Paste an instance of Component A and apply a string variable to the text layer.
  3. Within Component B, create a text property for the text layer and expose this nested property in Component A.
Result:
As a consequence of the described steps, we are unable to modify the text within the instance.
Luke_Snitter
Sep 8, 2023 10:05 AM UTC
I also agree that not be able to apply variables to nested components greatly reduces the ease for using them when prototyping. I have been stumped by this limitation several times and had to default back to having loads of variants or simply just moving from page to page, which complete defeats the point of why they rolled out variables in the first place. I also brought this up in another post Swap a variant instance using modes and a string variable and it would certainly welcome a quick fix!
Luke_Snitter
Sep 8, 2023 10:06 AM UTC
Yes, totally agree. I feel like this shouldn’t be a choice.
