Brian_Olson
Nov 13, 2024 3:50 PM UTC
Allow pasting from Illustrator as Vector
When I copy assets from Illustrator and then paste into Figma, it pastes as a raster image.
Keep it as a vector when I do this workflow.
Nov 29, 2024 12:51 PM UTC
Hey there,
Could you try exporting the vector as an SVG from Illustrator and then importing it into Figma, rather than copying and pasting? This might resolve the issue. You can find more detailed guidance in our Help Center article here: Copy assets between design tools.
Here’s another thread with additional workarounds that might be helpful for you:
If the problem persists, please reach out to the support team for further assistance here.
Be sure to use your Figma email account and share the SVG you imported into Figma. If possible, also include a quick video demonstrating how you copy the vector from Illustrator and how it pastes as an image instead. Thank you!
Brian_Olson
Dec 2, 2024 3:30 PM UTC
Hi Celine, thanks for the response! No this is not an acceptable solution. Exporting then importing a file is way less efficient than a simple copy/paste. This is a high traffic workflow so it needs to be efficient. Copying and pasting a vector is a rudimentary task that professional grade design software must support out of the box - no fiddling with configuration.
Adobe has a nearly quarter trillion dollar market cap. For a company of this caliber, it needs to be better with the UX of basic tasks.
I just noticed a ‘Ask the community’ tag on this thread. If I want this reported as a needed improvement, should I repost this as a ‘Share an idea’ post?
Dec 2, 2024 5:35 PM UTC
Thank you for sharing your feedback—I completely understand your frustration.
We’ll pass this along to our internal team for consideration. I’ve also updated your topic to ‘Share an Idea’. Thank you!
Brian_Olson
Dec 2, 2024 5:54 PM UTC
Thanks so much, Celine! 😃
Rob_Marquardt
Dec 2, 2024 6:04 PM UTC
In Illustrator > Preferences > Clipboard Handling do you have “Include SVG Code” checked? I’ve copied vectors from Illustrator and pasted into Figma for as long as I can remember.
Brian_Olson
Dec 3, 2024 7:11 PM UTC
Yes, I have that setting checked.
Brian_Olson
Dec 3, 2024 7:15 PM UTC
An observation if helpful: If I delete all text elements in Illustrator, the remaining elements will copy/paste correctly into Figma.
Rob_Marquardt
Dec 4, 2024 6:16 PM UTC
That was my followup… whether you had any text objects in Illustrator that hadn’t been converted to outlines. 😁
Prakash Sharma
Aug 7, 2025 5:57 AM UTC
There’s text in the document, but even if I copy just the vector object (without selecting the text), it pastes into Figma as a raster image. That wasn’t happening before. Deleting all the text objects from the document works fine.
Prakash Sharma
Aug 7, 2025 6:06 AM UTC
You can copy the Illustrator vector object and paste it into Figma as a vector object when there is no text object in the Illustrator file. If there is a text object in the Illustrator file, then no matter whether you copy the text object or not, the vector object will be pasted as a raster image. This is a new issue that requires fixing.
