Brian_Olson
Nov 13, 2024 3:50 PM UTC
Allow pasting from Illustrator as Vector
When I copy assets from Illustrator and then paste into Figma, it pastes as a raster image.
Keep it as a vector when I do this workflow.
izzy elinson
Aug 14, 2025 6:55 AM UTC
What you need to do is:
Go to illustrator / preferences / Clipboard Handling / Mark “Include SVG Code” and Unmark PDF.
Achieve Studio
Sep 12, 2025 12:11 PM UTC
I was having the same issue and tried everything mentioned here without results, then I just selected the object in illustrator and went to Object > Expand Appearance then I tried again and it worked! I also instead of grouping it I use pathfinder to united and simplify vector structures, Hope this helps!
MikeCodex
Sep 16, 2025 1:33 AM UTC
Unfortunately I’m having this issue as well. Yesterday, Copy from Illustrator → Paste into Figma was working perfectly, but today it’s no longer pasting as vectors.
I’ve tried all of the suggestions in this thread (clipboard preferences, ungrouping, expand appearance, restarting apps etc.) with no luck. It just keeps coming through as a PNG.
Any other suggestions would be greatly appreciated.
Krissan_Pattugalan
Sep 16, 2025 2:51 AM UTC
This was happening to me as well. To paste a vector from illustrator, make sure that you aren’t posting it into any frame or grouping or component. Just the path onto the pasteboard. Then you can get that vector and paste it into more complex structures.
Prakash Sharma
Sep 16, 2025 4:37 AM UTC
I recommend deleting the text object from the document entirely or simply expanding everything to paste it as a vector object in Figma.
FlickCM
Sep 18, 2025 6:43 AM UTC
I’m having this issue as well, like others above, my clipboard settings are set to include SVG code in Illustrator, I have no other text in the document, it’s set in RGB, no gradients or fancy effects and I have expanded the stroke into a shape. No matter what it keeps being pasted as a raster image.
Constella
Sep 18, 2025 3:28 PM UTC
This is the second time this problem happens to me. The first time I fixed it through the «include svg» check in Illustrator. Then, a few days later, Illustrator had an update and it has since stopped working again.
Kaap
Sep 19, 2025 1:46 AM UTC
I’m having the same issue as others described above.
It used to work for me after checking ‘include svg’ but now nothing works. Every item I copy and paste from illustrator into Figma pastes as a rastered image. Incredibly frustrating.
Kaap
Sep 19, 2025 1:56 AM UTC
I can confirm, downgrading to a previous build of Illustrator resolves the issue.
Prajesh
Sep 24, 2025 9:55 PM UTC
Made a illustrator script. You can use this to copy the code and paste it in figma. Not ideal solution but this is the easiest i could think of without exporting SVG over n’ over again.
Download file here: https://www.transfernow.net/dl/20250924ADmUgXx0
How to use:
  1. Select the object you want to copy.
  2. Run the script from File > Scripts > Other Script (load the file)
  3. It will open the SVG code of that object. Copy and Paste it in figma
Hope this helps.
Cheers.
