Equinusocio
Jun 22, 2023 8:10 AM UTC
Add way to change opacity for color variables alias, fills, strokes, etc
When aliasing a color variable to another (img 1), or using it directly on an element (img 2), we should be able to override the opacity without the need to create a variable for each transparency variation:
Cant override opacity in the alias:
CleanShot 2023-06-22 at 10.09.00
Example 2
Cant override the fill opacity:
JacksonSingleton
Jul 18, 2025 8:33 PM UTC
Does anyone have any sort of workaround? Most of my components use a background color on the base frame. I would have to rebuild my entire design system, or 10x the number of variables I have while losing the ability to reference the root color. How is this not addressed or supported?
Nathan2
Jul 24, 2025 6:22 PM UTC
+1 - Would love to have tokens for opacity independent of tokens for color
yujinyujin
Jul 30, 2025 4:32 PM UTC
+1. It would allow for so much more flexibility. Would be amazing to be able to pair set opacity tokens WITH color tokens
arda0
Aug 26, 2025 12:44 AM UTC
+1
Need this ASAP.
Lukas24
Aug 27, 2025 7:09 AM UTC
Any news about this? Still desperately need this!
Recep_Kutuk
Oct 14, 2025 11:09 AM UTC
FYI 😊
Michal_Swiaczkowski
Oct 20, 2025 1:24 PM UTC
​@djv Hey, any chance this will be added? CSS allows it, but Figma doesn't. 😭
Matt Frederick CTS
Nov 17, 2025 10:56 PM UTC
+1 here. We just started using variables for color while merging/simplifying color themes. Looking and not finding that feature was kind of a let down. :)
Pascale D'Offay
Dec 3, 2025 2:27 PM UTC
​@djv
Same issue.
The only workaround I could find was to create a gradient of the same variable and then it lets you add opacity to it.  But that’s still not a viable solution.  It’s been over a year since the first request was posted.  Please can we add opacity to a variable!
Screenshot 1: Gradient fill with opacity applied
Gradient fill allows you to add opacity
Screenshot 2: Gradient setup using the same variable added twice
1x variable used to create the gradient
Jeremy_Knudsen
Dec 16, 2025 6:41 AM UTC
So, it’s happening finally ???
