Equinusocio
Jun 22, 2023 8:10 AM UTC
Add way to change opacity for color variables alias, fills, strokes, etc
When aliasing a color variable to another (img 1), or using it directly on an element (img 2), we should be able to override the opacity without the need to create a variable for each transparency variation:
Cant override opacity in the alias:
CleanShot 2023-06-22 at 10.09.00
Example 2
Cant override the fill opacity:
Recep_Kutuk
Apr 17, 2025 3:42 PM UTC
+1 This would be a very valuable feature for design system  management!
Recep_Kutuk
Apr 24, 2025 10:25 AM UTC
+1 to any suggestion that involves breaking the link between color and opacity.
Melanie_Sorensen1
Apr 28, 2025 3:06 PM UTC
This is needed for Angular 19 Material components.
Lee_Beth_Kilgore
May 2, 2025 8:45 PM UTC
following… me three (hundred) 🙋🏼
Uhl
May 7, 2025 4:21 PM UTC
+1 Just started using variables and while they’re great, it feels incomplete without this. Any solid color system needs to support defining variants relative to a base color.
Alice_Holm
May 27, 2025 8:42 AM UTC
+1 This is much needed
Sharon_Taylor
May 31, 2025 9:49 PM UTC
+1 this - definitely need this for the color system
Chris_Gatland
Jun 9, 2025 9:48 AM UTC
+1 from me.  Not having separation of transparency and colour variables is going to cause me lots of extra work, and will result in a messy design system that’s hard to manage.
Alex_Karoza
Jun 20, 2025 6:17 PM UTC
Or even better, allow modification of any values based on the original variable.
For example, changing Hue in HSL or Alpha in CSS.
With LAB+LCH/OKLCH color systems supporting updates, it will be HUGE!
It can change the way people think about color.
For other variables, it will also be beneficial; for example, to dynamically align inner and outer border radii.
schoon
Jul 14, 2025 6:42 PM UTC
+1 Also needing this feature
