Equinusocio
Jun 22, 2023 8:10 AM UTC
Add way to change opacity for color variables alias, fills, strokes, etc
When aliasing a color variable to another (img 1), or using it directly on an element (img 2), we should be able to override the opacity without the need to create a variable for each transparency variation:
Cant override opacity in the alias:
CleanShot 2023-06-22 at 10.09.00
Example 2
Cant override the fill opacity:
Tiago_Gomes
Jan 28, 2026 4:22 PM UTC
For all ppl out there apparently you can make a Linear gradient with the same color and them add a transparency on the side panel :P
Recep_Kutuk
Jan 30, 2026 9:50 AM UTC
But what’s the point? Consider this: The most convenient use case (for me at least) is selecting a component and clicking on “Selection colors” option to change necessary colors easily. There’s no work around to enable this.
wiresnchains
Feb 1, 2026 1:59 PM UTC
Any updates on this? The absence of this feature is messing with my projects for over 2 years now.
Pascale D'Offay
Feb 10, 2026 1:49 PM UTC
Hey @Henrik_Andersen, thanks for the feedback!
@Alok is correct that this is currently expected behavior. I updated your topic for clarity, and we’ll pass this onto our team for future improvement.
Be sure to also vote up top! ☝️ Our teams use votes to gauge overall interest and prioritize.
​@djv  any update?
James_Walsh
Feb 26, 2026 1:16 PM UTC
I’m using this work around for a few small edge cases - thanks for pointing it out.
I cannot wait for a future where I can build a cascading color system that let’s me change the root values and everything just adapts.
Kinda insane we’re still here asking for this in 2026.
DanVP
Feb 27, 2026 10:47 PM UTC
This is another one where I wish that absolutely every text or number field would accept variables in them. I would love to be able to set the fill color opacity as a variable, and the H/S/L values as well, etc.
Kerry_Johnson
Mar 1, 2026 1:38 AM UTC
Tried creating a new color style and the gradient hack above (cool trick if you just need to hand-key opacity in), none of them allow setting the opacity as a variable.  So for now I’ll just create a layer above and set variables on Fill color and Appearance opacity until we get support for this in.  I am glad with the recent updates to Figma and glad they are hopping off the AI train some.
Shane Yu
Mar 2, 2026 4:31 PM UTC
The absence of these core features is a significant oversight, especially considering the long-standing community demand. Their continued omission suggests a disconnect between product development and actual user requirements.
Our current workflow for building design systems and implementing variables is inefficient. We are forced to rely on complex, time-consuming workarounds to compensate for these functional gaps, which compromises our productivity.
Figma’s current market dominance appears to have led to a plateau in meaningful innovation. The platform requires more rigorous competition to incentivize the delivery of essential updates and quality-of-life improvements that professional users require.
Variables Plus
Mar 3, 2026 9:02 AM UTC
I hit the exact same limitation and it drove me nuts.
Figma doesn’t let you override the alpha/opacity of an aliased color variable without detaching, so you lose the reference. I built Variables Plus to solve this class of problems by adding formulas on top of Figma Variables.
With Variables Plus you can keep Blue-950 as the single source of truth, then create derived variables like “Blue-950 @ 50%” (or drive the alpha from a separate opacity variable) while staying fully linked — when Blue-950 changes, all opacity variants update automatically.
Example: I reference Blue-950 and apply a 50% opacity formula. If Blue-950 changes later, the derived color updates too, while always keeping 50% opacity.
Plugin: https://www.figma.com/community/plugin/1607106236822235286/variables-plus
Demo file (duplicate-ready): https://www.figma.com/community/file/1607096708474658929/variables-plus-demo
​@Henrik_Andersen ​@Shane Yu ​@Pascale D'Offay ​@wiresnchains ​@Alok ​@Jared_r ​@Melanie_Sorensen1 ​@wgo ​@djv ​@Recep_Kutuk ​@Lukas24 ​@Michal_Swiaczkowski ​@Vishwajeet_Bhadouria ​@Matt Frederick CTS
Pascale D'Offay
Mar 3, 2026 10:17 AM UTC
​@Variables Plus that’s very nifty - thanks.
My only issue is that the developers would require the variable to remain intact in the code.
It appears that your plugin displays it as a hex code (that’s linked to a variable) rather than reference the variable itself.  We would need the variable with opacity applied (my version using a gradient fill still achieves this, but it is duplicated into a gradient)
